Question about Dynasty DGRSC 36-4CB Gas Kitchen Range
Oven has stopped working
I have a 36" Dynasty range with griddle. The oven stopped working yesterday, while everything else is working fine. I took the bottom pan out and noticed the ignitors weren't lighting up and there is no smell of gas, so I assume the gas is not flowing. Any idea what's wrong? I'm fairly handy. Is this a something I can fix on my own if I had the part?
  • 93 Answers
Bad oven ignitor, to check it, turn on the oven, check Voltage on 2 ignitor wires, it should have approx. 110v, if yes, change the oven ignitor, if not then check oven safety valve of oven thermostat, but 90% is the oven thermostat. also make sure the oven tube is not corroded at the ignitor area, if so, change the oven at the same time. Have fun.
Posted on Mar 02, 2010
  • Po Hang Fung Mar 02, 2010
    my mistake I said ( 90% is the oven thermostat and it is wrong). what I mean is 90% is the oven ignitor. Also at the end I said ( change the oven at the same time ), NO don't change the oven, I mean change the oven ignitor.
Oven takes a long time to heat
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 24, 2011 | Dynasty DGRSC 36-6 Gas Kitchen Range
Need instruction book
Jade / Dynasty ph# 800-884-5233, most cases the big BANG noise is coming from the broken oven bottom pan, small BANG is normal, if you know how to remove the bottom them pull it out and inspect it, part of the V shape flame spreader may come off from bottom pan, you can have the welder weld it back on for you or order new bottom pan thru Dynasty. I'm not sure what do you mean by gas shut off. (turn off oven? turn off burners?)
Mar 22, 2009 | Dynasty DGRSC 36-4G Gas Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Dynasty range - oven feature has stopped working
it's very possible that the mice may have gotten in but i would say it's the ingnition electrode.
i would have a technician come and take a look. check you local authorized repair shops. shouldn't cost you more than $150.00 to repair it.
Sep 13, 2008 | Dynasty DGRSC 48-6G Gas Kitchen Range
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty DGRSC 36-4CB Gas Kitchen Range Logo
302 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
