Question about Kitchen Ranges
Model # 8114p852-60 oven comes on - Kitchen Ranges
Glow stick comes on but oven will not light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Nov 22, 2010 | Amana AOGD2750 Gas Double Oven
Ignitor for oven comes on but gas release cuilds up before oven ignites causing a voom
I have a Kenmore Gas Range, model 72503. #1 problem-the orficies were not installed properly; #2 problem-when I turn the top burners on, gas comes out before the ignitor comes on. I called Sears, they sent someone who said that the burners can't be adjusted. I feel this is very dangerous. This is a new 2011 model, made for Sears by Frigidaire. Who should I contact about this problem. Sears say it is out of their hands. Help!
Sep 12, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven dosen't heat up.
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at http://appliancehelponline.com/ovenelementvideo.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Jun 08, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
