Question about Intermec EasyCoder® PM4i Printer
Intermec Pm4i Printer is printing labels fine just not feeding last label out far enough to tear label at the preforation in gap. Have tried adjusting LSS with no change, ran calibration with no change, did a testfeed with no change.
  • 14 Answers
SOURCE: mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Posted on Jul 03, 2009
SOURCE: Intermec PM4i I have 4x6 labels
Check your driver to make sure you have the correct resolution driver installed that matches your print head. For example, if your print head says 203 dpi on it but you install the 300 dpi driver, it can cause this problem.
Posted on Oct 01, 2010
SOURCE: The Thermal transfer labels are
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
SOURCE: ribbon feeds out with label on the intermec
Check to make sure that the printer is set to Thermal Transfer and not Direct Thermal. If the printer is in Direct Thermal, the ribbon take-up does not turn.
If the printer is set to Thermal Transfer then I would suspect a bad Power Supply since the ribbon take-up is driven by the power supply and not off the main board.
Posted on Dec 06, 2010
  • 6 Answers
SOURCE: Hi, can anyone think of why a Intermec PM4i
Make sure the platen is cleaned and there isn't too much tension on the print head.
Posted on May 27, 2011
How do I adjust the tear off length of the printer label on a PM4i
I think the setting you are looking for is commonly reffered to as the label restpoint for Intermec.
Jul 08, 2014 | Intermec EasyCoder PM4i Printer
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
Ribbon feeds out with label
Your take up spool isn't working properly, bad motor or belt.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
Mis align printout
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Label not printing
Firstly, check your software settings, sometimes you need to reduce the print speed a bit, and turn the darkness up... if there is a knob for print head pressure adjustment, turn it up! i'd also clean the head and platen roller with isopropyl alcohol, failing all of the above, contact your media supplier and check that you have the correct media combination. hope this is of help to you, Markus.ps Failing that ...if you need a trained intermec engineer....... contact Precision Peripherals.... jrichards@printer-service.co.uk
Jan 23, 2009 | Intermec EasyCoder PM4i Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder® PM4i Printer Logo
51 people viewed this question
Top Intermec Office Equipment & Supplies Experts
pkwc
donjackson
Level 1 Expert
Paul Bade
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
