Question about Dryers
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
  • Dryers Master
  • 3,289 Answers
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Posted on Jan 07, 2013
  • Steve Jan 07, 2013
    The document link for page 63 didn't get added to my reply - so you'll have to copy & paste it from here: http://www.scribd.com/doc/64932260/Whirl...
SOURCE: dryer gets hot but wont dry clothes
should the top of my 10 year old Maytag dryer feel almost hot to the touch
Posted on Oct 11, 2009
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool Dryer- Model #YLEQ5000PW0, does not get
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 06, 2009
  • 77 Answers
SOURCE: Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Posted on Mar 20, 2010
  • 102 Answers
SOURCE: There is condensation on the front and back of my
Is the drier getting hot? If so then the air flow is restricted by a dirty lint filter or blocked vent pipe.
Posted on Apr 11, 2010
  • 2006 Answers
SOURCE: My Dryer takes forever to dry almost 2 hours for a
I would first check the lint screen, if it is blocked it will slow air flow and the heat won't circulate properly. The next thing I would check is the exhaust pipe to make sure it isn't clogged for the same reason.
Neither of those cost anything for you to fix, so you need to check them first. The next item will cost some money. You will have to open up your dryer and check the heater element with an ohm meter to make sure it has not broken. And open/infinity reading on your ohm meter means you will need to replace it. If it is good the next suspect is the thermostat. Basically, the thermostat is harder to check with an ohm meter for a Roper because they will change to a different thermostat during a model run. Since they aren't very expensive, I would change it if I opened up the unit. The last thing that I would suspect is the control board but it is a possibility.
Posted on Aug 28, 2011
Whirlpool AWZ 8578 - does not stop, always needs manual switch off
These symptoms most usually are a bad timer/control. If the dial turns all by itself, and continues to turn by itself like a clock does, it is likely a timer/control must be replaced. Same results if it will not advance by itself either.
You could type in "Sears Parts" for the new part, typing in your complete model number. If you wished to try a used control, after obtaining a part number, you could type that in to "e-bay" and see what you find in new or used parts there. I do.
Be blessed.
Feb 15, 2014 | Whirlpool Dryers
Awz 412 washing machine/dryer.
With a washer and drier thay do , a separate drier would be better for you
Dec 13, 2017 | Whirlpool Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Whirpool awz 7466 is not drying
check regulator, gas and thermal fuse
Nov 03, 2013 | Whirlpool Dryers
I have a Whirlpool commercial dryer model number LEQ7030KQ1. I will wash a load a clothes in the wash machine and they will come out so they are as spun dry as they can get. The problem I experience is...
Did you mean that you need to press manually to have the drying done well, if so the program settings is what is wrong?
Does a good timing setting work on the set?
Please clarify more.the fault you are.experiencing.
Sep 28, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Mar 20, 2010 | Whirlpool Dryers
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dryers Logo
1,012 people viewed this question
Top Dryers Experts
