Question about GE DBL333EA Electric Dryer
Dryer switch grinds and sometimes starts, most times not
GE DBL333EA Electric Dryer. The dryer will grind to a start by holding down the switch, only after a long period of rest. If the dry starts, it functions normally. If the dry doesn't start, it is usually after an initial run cycle.
  • 3 Answers
Sounds like the overload switch is cutting out , my gues will be that the motor is going bad. Just replaced mine was doing the same thing.
Posted on Feb 09, 2009
I have GE dbl33eb4ww dyer that wont get clothes dry till you run them through about trhee or four times
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | GE DBL333EA Electric Dryer
My dryer is squeeking and grinding, but not all the time. What could be wrong? When it first starts, it sounds like it is grinding, but continues to work. After a few minutes, it stops. Then it will start...
One of two issues is going on, or maybe both. The first cause for the grinding noise is going to be the main bearing that is bad, and needs to be replaced. The squeaking is actually coming from the belt. So I would check under the unit and make sure that you do not have any metal shavings under the unit. Then also check the belt
May 18, 2010 | GE DBL333EA Electric Dryer
My dryer, bought in June '09 just started making same scraping noise. does not make noise when you hold dryer door open and hold in the door-closed button.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dsaf
Feb 25, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Grinding, scraping noise when drying
Glides or roller replacement, could also be something from a pocket wedge between drum or cabinet.
Feb 01, 2009 | GE DBSR453EBWW Electric Dryer
GE dryer has trouble starting.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jan 20, 2009 | GE DBL333EA Electric Dryer
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
GE DBL333EA Electric Dryer Logo
110 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
