Question about Epson Stylus C60 InkJet Printer
Red light stays on..loud noise made as carriage moves to right..
Paper is not jammed..ink is fine...pushing ink replacement button gets no movement......is the nylon ribbon stripped?
  • marrionj Mar 12, 2009
    What is the parking mechanism? Can I get an illustration somewhere? Thanks
  • Gerry Millward
    Gerry Millward May 11, 2010
    Turn the printer on and as soon as the print head tries to make a move, pull the power cord out of the back (or turn the power off at the mains switch). See if you can now move the print head by hand away from the parking position on the right. If so, see if the parking mechanism is broken or jumped out of position so that it fouls the print head. Report back.
  • 353 Answers
If you don't respond to queries it is very difficult to help you. If you still have this problem can you respond with a comment, otherwise we will call it solved.
Posted on Feb 14, 2009
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
When the carriage moves to the right,there is a loud crunching noise, red light comes on.
Check to make sure, no staples or paper lodge.
Check it with a flashlight.
Good Luck..........
Jan 22, 2010 | Epson Stylus C60 InkJet Printer
Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Oct 31, 2009 | Epson Stylus C44UX InkJet Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
1400 carriage
if the printer power light is off and the paper and ink light are flashing there are a few things you can try.
1. remove all paper from the printer.
2. lift cover and check for paper jam
3. check to see that the ink cartridge cover is completley closed. (the covers do actually pop themselves open and jam)
if none of these fix your problem then your in the hands of epson tech support. they can be reached @ 562-276-7282
May 12, 2008 | Epson Stylus 1400 InkJet Photo Printer
Ink carriage jammed
Well, I'm not too happy that the only response I got was solicitation for the Premium Assistance Plan.
Figuring that the printer had pretty much died, I allowed my husband, Mr. Fix-It, to give it a try. He simply pushed up on the front end of the ink carrier and slid it into the opening. This allowed him to get at the cartridges and push gently down on the new cartridge I'd installed. It had not been seated completely. Works fine now.
I'd be curious to know why I found a huge ink spot under the printer. It has probably been there for quite some time, as I usually just dust around things rather than move them.
Mar 14, 2008 | Epson Stylus C84 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
