Question about Sharp AR-M455N Copier
Sharp ar-m455n code l3-00 - Sharp AR-M455N Copier
  • 7 Answers
SOURCE: Duplex Set-up fro Sharp AR-M455N
does the machine have a duplex fitted? as it is an option for this machine either called a du3 or du4. It bolts onto the left hand side of the copier. On the lcd touchpanel you should see it sais 2 sided next to the output box, tap it and select 1 to 2 or 2 to 2 depending on your origonals.
Posted on Dec 06, 2008
  • 990 Answers
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
007tech
  • 95 Answers
SOURCE: I have a sharp ar-m455n and it is stuck on 59%
Something the fax received into memory has corrupted its RAM or it received bad data/info. You can clear this problem by going into service mode by pressing the following keys : (PS. you must be in copy mode) P * C * then enter 66 and "start" then you can use "7" to try and print out what is stuck in memory or enter "10" to clear out the image memory then press "start".
Reset copier after that and you should be good.
Posted on Mar 22, 2009
  • 54 Answers
SOURCE: Sharp AR M455N copier scanner will not scan to Windows 2000
Check the webpage under destinations and make sure the IP address is correct for this pc. can get to webpage by opening Network Scanner tool, hitting the scanner tab, then web setup button.
Also make sure the Network scanner service is running in the system tray (by the clock) and that it says the service is started by hovering over it with pointer.
Posted on Apr 17, 2009
xptareq2000
  • 1447 Answers
SOURCE: error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Posted on Dec 16, 2009
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Tray
sir my machine sharp AR-m420u take code H3-01 whats meen this code......?
Dec 03, 2013 | Sharp AR-M455N Copier
SHARP PRINTER AR-M420u ERROR CODE H5-01 RESET
Sir my mchine take code H3-01 whats meen this code.....?
Aug 12, 2012 | Sharp AR-M455N Copier
Error code U2-22 Model #AR-M455N what's wrong with the copier?
MFPC SDRAM memory check sum error. Remove the back print control board (shiny metal + slides out like a draw) remove and refit memory cards.
Sep 27, 2010 | Sharp AR-M455N Copier
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Sep 05, 2010 | Sharp AR-M455N Copier
Need to download latest printer drivers for Sharp copier AR-M455N
Copy this link to download the driver needed
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 15, 2010 | Sharp AR-M455N Copier
Sharp ar-m455n- f1-15
Finisher liftup motor trouble
Apr 09, 2010 | Sharp AR-M455N Copier
Error code L4 30
Dec 16, 2009 | Sharp AR-M455N Copier
Sharp AR-M455N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
