I need a manual for MajCo gas fireplace model Gas 36DV88
  • 5 Answers
SOURCE: need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Posted on Jan 26, 2009
SOURCE: marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Posted on Jan 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 09, 2009
SOURCE: Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Posted on Dec 14, 2009
  • 3315 Answers
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Posted on Feb 25, 2010
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
Gas fireplace lights up but only half the burner stays on after running for a few minutes
Do not operate this fireplace until problem is solved.
Could be low gas pressure, or dirty combustion parts, or bad gas control valve.
Contact gas company immediately for specialist in area.
If burner is dirty and clogged, then unburned, explosive gas can be going up the flueway. This is a dangerous condition that needs to be addressed before putting fireplace back into service.
Web-search your specific brand and model number, and include .pdf in search parameter for possible downloadable product manual.
Read product manual for advisories and maintenance and troubleshoot and warranty.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 13, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Temco gas fireplace manual adl 36-1
where can I find a manual for a ADL 546-1 termco vent free gas fireplace. Really need your help as the township is requiring certification for these fireplaces. thanks
Jan 02, 2012 | Pool & Spa
I am looking for a manual for a Security Fireplace Model SRGH36R can you tell me where to get one??
Security Fireplace ceased manufacturing gas fireplaces almost 8 years ago. So, finding an Owners Manual for your model would be almost impossible. Although, if you can locate a hearth (Gas fireplace) dealer in your area, that did sell them at one time, they may be able to help you.
Sorry I didn't have better news for you.
Apr 15, 2011 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Need Help
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
