Question about Maytag MSD2456G Side by Side Refrigerator
Water and Ice Dispenser not working
I have a Maytag MSD2356AEB side by side refrigerator and the unit is making ice and I can retrieve it by opening the door.
The problem however is that the water and ice dispenser are not working in the door. I do not have any lights either, so I assume it is some sort of an electrical problem.
The contact switch appears to be free as I can push on it where the glass typically makes contact. Before I try and pull this apart, I was wondering how difficult it would be to open up the dispenser to check for a loose connections or replace a board or fuse.
  • vitalsynch Jan 22, 2009
    Thanks for the advice, but the connector does not appear to be the issue.
    Does anyone know whether or not there is some sort of a fuse behind the dispenser?
    My guess is that I either have a loose connection, a fuse, or a bad ciruit board. My real question, is how difficult is it to take apart the dispenser unit to get to the possible meat of the problem/
    I could not find a downloadable repair manual to see how much fund taking this apart might be.
    Thanks to all that offer assistance.
  • woodpckr Feb 08, 2009
    my icemaker is sending ice down the opening but the round door that lets it in the glass isn't opening. so the ice just builds up inside the canal.
Vitalsynch, did you find solution to the ICE/Water problem? I have the same issue.
Thanks
Dan
Posted on Apr 24, 2010
  • 700 Answers
First i would check the connector on the hinge of the door to k=make sure its made al the way.
Posted on Jan 21, 2009
Ice maker not making ice
The solenoid that lets water into the ice maker is not working. The ice maker itself can also cause a working solenoid to malfunction.
Jan 15, 2014 | Maytag MSD2434GE Side by Side Refrigerator
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
My Maytag refrigerator has an ice maker that will not shoot out ice. the ice maker will make ice and send ice to the door where it comes out but the door needs more pressure in order for it to open. I can...
the door has a solonoid the opens it and is not working . ice does not put the pressure on the door. look for bad sol. or linkage to sol . or bad pc board that tell it to open .. ****
Jan 12, 2010 | Maytag 25.6 cu. ft. Side-By-Side...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Water dispenser quit working
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Maytag MSD2456G Side by Side Refrigerator Logo
170 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
