Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Top burners spark intermittently with burner valves shutoff
The range is a model jdr8895aas duel fuel when the problem happens it sparks just once
    President:
  • 1,214 Answers
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Posted on Jan 20, 2009
How do I remove the control panel
The best way to do this for your particular model is from behind the range itself. Before you start be sure to unplug the range. Now, standing behind it, remove the upper section that is the back of the range heading. 5 or 6 screws should be about it. Once you have that removed you'll be able to see the control inside there, usually held in with a few screws, likely to be 1/4" in size. The rest is self explanatory. Good luck
May 11, 2012 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I purchased a jenn-air model JDR8895AAS LPgas range and want to convert it to natural gas.What do i need?
you may need to not change anything but i have not experienced that yet but look around and see if you pull anything up on google
Jan 02, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How can I disable Sabbath Mode on my Jenn Air JDR8895AAS
Sabbath Mode on this model can be disabled by pressing the "CLOCK" button and holding it for 3 seconds. "SAb" will then flash for 5 seconds, then return to normal display. Sabbath Mode will also automatically turn off after 72 hours.
These instructions are listed on page 16 of your owner's manual. If you no longer have a manual, you can obtain a replacement copy at managemylife.com. Just enter your model number under their "Manuals" link and you will find the owner's and installation manuals available in .pdf format. You can download or print a copy for FREE.
For your convenience, here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/3891/JENN-AIR-Range-Electric-Gas-L0411320?brand_name_search=jdr8895aas
If you require additional assistance, please post back and let me know. I hope you find this information helpful.
Oct 25, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Several Gas Burner Igniters spark every 5 seconds even when all burners are turned off. Jenn-Air Dual Fuel Range JDR8895AAS Help, and Thanks! -- Larry
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Jan 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Spark ignition clicks every 5 or 10 minutes with burner valves off it is not continus spark it sparks once
Sounds like one of the four switches attached to the burner control knob may have failed where the switch does not fully open. This could be due to moisture or grease having seeped into the burner control/switch.
You can find a wiring diagram for this unit at www.SearsPartsDirect.com by typing in your model number.
Reply back if you would like further help.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
All igniters sparking
the only thing which I found is after I clean the burners, maybe some dirt in.
Jul 06, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn air duel fuel problem
Depending on where you purchased the range find out if it is satisfaction guaranteed then either get a new range delivered or your money back. You need a burner selector switch to solve the problem.
Dec 09, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Dec 01, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
309 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
