Question about Intel Motherboard
Start up My computer configuration is P4 motherboard intel. I click my cpu power then i can expect normaly start. but this computer can't start. showing message of this computer. Please select boot device or boot media.
  • 2,992 Answers
That message will appear when there is no boot record found on any device the system board tries to boot from. This probably means that your hard drive is not being detected, does not have a bootable copy of Windows on it, or is defective.
Make sure the drive is correctly listed in the motherboard setup screens. If it is not, check for proper power and data cable connections at both the drive and main board. If the drive is being correctly identified, you may need to reinstall your operating system.
Posted on Jan 20, 2009
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
Mar 08, 2010 | Intel D845HV (735858149143) Motherboard
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
Apr 16, 2009 | Matsonic MS9337c Motherboard
What does it think your cpu is?
Mar 14, 2009 | Intel ASUS P4SC Socket 478 Pentium 4...
PC Freezing !
Update BIOS to P25*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Clear your bios, remove your all pci cards & then try.
Feb 23, 2008 | Intel D845GVSR Motherboard
P4 ugrade required
Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
An article on socket 478 for you
Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
