Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
The fan on my 3100 runs normal when I first boot up then it starts running faster and faster then it tottaly shuts down. the fan works fine. could this be the processor?
  • HP Master
  • 5,660 Answers
The Thermal Paste in-between the Processor, and Heatsink, has dried up.
Use a plastic scraper to clean top of Processor, and bottom of Heatsink. I use an old credit card.
Scrape off as much as you can.
Use Q-tips dipped in Isopropyl Alcohol. Don't worry about dripping off, alcohol will evaporate.
Takes a LOT of alcohol dipped Q-tips, as it's usually a gooey mess.
CAUTION!!
Isopropyl alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present.
When the Processor, and Heatsink are clean, and dry; properly apply fresh, new Thermal Paste.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3999975&CatId=503
http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Paste/274
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3440586
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01049892&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3440586
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07139&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3440586
FOLLOW Anti-Static Precautions.
If you are not aware post back in a Comment.
Regards,
joecoolvette
[Plus your computer is probably dirty inside. Use a can or two, of compressed air for computers to clean it ]
Posted on Jan 07, 2013
  • 1 more comment
  • joecoolvette
    joecoolvette Jan 07, 2013
    A Processor turns off if it overheats. (BIOS turns it off) This is a fail safe feature built-in. Keeps the Processor from burning up. Thermal paste dried up, processor overheats. Fan races to cool Processor off, can't; and BIOS turns Processor off.
  • ralling Jan 07, 2013
    I have done all these things. The problum remains. Thanks
  • joecoolvette
    Computer off, and unplugged from power. Press the Power On button in, and hold it in for a count of 10 seconds. Count, 1001,..1002,..1003,..etc. Do this same procedure 2 more times. Plug the computer back into power. WAIT 1 minute, turn the computer on. What you are doing is clearing CMOS Error Codes, and resetting BIOS Setup back to the factory default settings.
scottyfixit
  • 186 Answers
SOURCE: Help !!!!my laptop shuts down
We had some Acers do the exact same thing and we fixed them. I believe it shuts right off as a safety. Usually when the processor gets too hot it powers right off to save the laptop from burning up. First quick fix it to blow out the vents and especially blow out the heat sink vent. Also could be that the heat paste that sits between the CPU and Heat Sink could have dried up and stopped doing it's job to remove heat efficiently from the CPU. Big problem in earlier model Gateway laptops too. This can be fixed by acquiring some paste from a local tech shop and reapplying it. If you feel unsure about it, take it to a tech shop and they can do it quick for cheap if not for free. Keep me posted - Scotty
Posted on Apr 30, 2008
quadrantmind
  • 14 Answers
SOURCE: Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Posted on Mar 19, 2008
ebay312
  • 118 Answers
SOURCE: Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
Posted on May 23, 2009
  • 3287 Answers
SOURCE: CPU fan error at boot.. Spin fan manually at power
The fan needs to be replaced. When you provide the "umph" to start the fan, it is able to continue by itself. The exposure to heat and the accumulation of dust and dirt has begun to interfere with its ability to start from a stopped position.
The fan should be replaced with an identical fan - preferably from a new CPU heat sink. Do not replace the entire heat sink unless you are prepared to clean the CPU and apply new thermal grease, etc. It is far easier (and probably just as good) to replace the fan only by removing both the old and new fans and swapping out.
Eventually, starting the fan by hand will no longer allow the fan to run by itself. It is better to make the repair now than have the fan fail and cause the CPU to over heat - possibly catastrophically.
Posted on Sep 15, 2010
shibuda
  • 1812 Answers
SOURCE: I have a a1630n and
Hi did you do it ? Restart the pc.
Posted on Nov 21, 2010
ACER ASPIRE X1200 Unexpected Shutdown
When does it shut down? Are you able to use it at all? Or does it shut down when you are trying to boot it up?
When it shuts down are you able to boot it right back up and start using it? If not, it might be running hot. If you let it sit a while to cool off then try booting and if you are successful, then it is definitely running hot.
Three things that will make a computer run hot.
1. Dust - Dust inside the computer, dust clogging the vents and fans. Dust around the cpu and heat sink. To fix, Remove the power cord, remove the case and take a can of compress air to blow out the dust.
2. A fan is not working. Make sure the fan inside the Power supply and the fan that sits on top of the cpu is working. Normally the system will notify you if the fan is not working. To fix, you will have to replace a fan that is not working.
3. The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. To fix, apply a fresh coat of Thermal Paste around the cpu and heat sink.
Maybe you have a virus or infection that is shutting you down if it is not running hot and you are allowed to work on the computer for a while before it shuts down. Boot the System in Safe Mode and see if it shuts down.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 24, 2012 | Acer Computers & Internet
After turning on my my acer 2300 its boots up fine but the fan only works for a few seconds then stops and then does not work at all
Normally if the fan is bad and failing the laptop will run hot (overheat) and shut down. If yours is not doing that, then you are fine. Sometimes the fans will turn on and off as needed.
Apr 01, 2012 | Acer TravelMate 2300 Notebook
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Overheating fan will not run ! I change cooling sensor, fan relay,new radiator, thermostat, fan motor, check all fuses, tank low coolint sensor, put fresh coolant in also. (1998 achieva SL 3100 V6 SFI )...
there isa short in the wiring somewhere,which a shop can check for you,or check your thermostat. after 20 years i still have to make sure tat i dont install it upside down. which is easy to do if your in a hurry. my bet is that the wiring going to the coolant sensor has a bare spot and grounding somewhere.
May 02, 2010 | 1998 Oldsmobile Achieva
Acer Travel mate 7730 os xp laptop shuts down
make sure processor fan is working fine. you may hear the sound of fan on the left side of the laptop. and make sure its not getting heat soon. If the fan is not working you need to replace the fan. If if gets heat soon that means you have to put processor cooling paste.IF the fan is working fine and the processor heat is normal, then you need to re-fix the RAM. Then it will work fine..ok
Jan 26, 2010 | Acer Aspire 3100 Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Boot issue
Start the computer and logon as normal,Once on the desktop,Click start,run,and type msconfig , Click OK, On the General tab,Choose Boot normally,Click apply,The computer will restart,click ok.
If this don't work,Post back
May 15, 2009 | Dell Dimension 3100 PC Desktop
Overheating
if fan is working well then it might have processor problem.
Nov 19, 2008 | Toshiba Satellite A105 Notebook
E Machine T2682 powers up but, doesn't work
This sounds like an overheating problem, that is why the fan comes on right away. When you let it rest, it cools off, and works normally for a while.
Most modern PC's are designed to slow down their operating
frequency when they over-heat, and if that is not enough they
will go into suspend, hibernation or (totally off) modes to protect themselves from permanent damage.
Solutions:
Bigger power supply, more and better cooling fans, improved space and airflow around the cabinet, cool the room with aircond.
also better heat-sinks on the CPU and/or the chip-sets.
all relatively inexpensive.
Apr 17, 2008 | E-Machines eMachines Desktop PC
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
