Question about Cuisinart Refrigerators
Need a new circuit board for Cuisinart Wine Cellar WBC 1200.
Have ac power to board but no dc output at any pin connection. Cooler is completley dead.
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Don;t know how it works
The manual is available from:
http://www.cuisinart.com/share/man/633_man.pdf
-Tha Mp3 Doctor
Posted on Feb 15, 2009
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
  • 534 Answers
SOURCE: Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Posted on Jan 29, 2010
Power supply failing on Cuisinart CWC 1600 cooler
The hayni made in china internal power supply has faulty transformers on it that fail within anywhere from 6 months to 2 years. Solution. Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box and it only cost 15 dollars. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. Now my wine cooler is more energy efficient and and will run for at least 5-10 years. This power supply replacement takes about 20 minutes. You need: philips screw driver, wire cutter and stripper, two 16 guage wire nuts. That's it.
Oct 12, 2012 | Cuisinart CWC1600 Wine Cooler
Removing the light cover on the cuisinart WBC 1200
Mine took a tamper proof torx head screwdriver to remove the screws. Hope this helps.
Feb 26, 2011 | Cuisinart CWC-1200 Wine Cooler
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
Stopped working. There does not seem to be any fuse to change. It is just dead.
The fuse is on the circuit board inside the back, located near the AC power connector. You will need security Torx bits to remove the screws. It's a metric 2.5 ampere fuse. However, chances are the fuse blowing is a sign that the little fridge has a bad circuit board, usually blown out by dust collecting on the outer heat sink causing overheating, the fans not turning anymore, or a voltage spike shorting out the switching power supply input diodes. This is a common problem with these. Finding a new board from Cuisinart is the solution.
Dec 20, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Refrigerators Logo
288 people viewed this question
Top Cuisinart Refrigerators Experts
Brian Coughlan
Tom Chichester
Darrell
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
