I am using an Asus laptop with Windows 7. When I turn it on it goes to Aptio Setup Utility. How do I fix this problem?
  • Zoe McKay Apr 14, 2013
    I'm having the exact same problem, what do i do?
    I'm having the same problem. If i save and exit, it just comes back to the main screen in aptio set up utility, help!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Go to save and exit it and you should be good
Posted on Jan 07, 2013
Well, try putting a x2 pc into the harddrive,open windraw V3, and type in %TR011ED, the code that will get you out of Aptio Setup Utility, but has a 99.7 percent chance of this entire thing not working.
Posted on Mar 23, 2014
ratheeshmoha
  • 349 Answers
SOURCE: My laptop will boot dos, but will not boot
Hello sir.your windows is bad.Please format your PC using win XP2
Posted on Sep 30, 2011
bronk50
  • 27725 Answers
SOURCE: unable to instaal windows 7 on Asus A3Ac
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Posted on Sep 21, 2012
sandrew
  • 2961 Answers
SOURCE: drivers
All the drivers for your Z71A system are at the link below http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Apr 30, 2007
patemi
  • 366 Answers
SOURCE: gateway laptop 450 rog
be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Posted on Jan 06, 2009
  • 265 Answers
SOURCE: Black screen and flashing white underscore.
Hi .
when you go into your setup ,go to disply and see if anything has changed?
let me know ...................good luck Roy
Posted on Feb 18, 2012
How can I get my laptop to come on? All I get is blank screen or Aptio Setup screen
try restarting your laptop and press f8 a couple of times it should give you a screen to allow you to start in safe mode click that and just follow on screen instructions.or you might get repair you can try that,or start windows normally.
Nov 20, 2016 | ASUS Computers & Internet
I have an ASUS Q501LA and it is stuck in the Aptio Setup Utility. How do I fix this?
Here are some troubleshooting steps you can try but definitely it's the HDD if you've done most of the troubleshooting with Asus Support.
- Start by disconnecting other devices connected to that laptop.
- Next is to load Aptio Setup screen and make sure that the HDD is set as the first boot device.
- If these will not work try loading BIOS into its default by pressing F9 while your in Aptio setup screen.
- Lastly, remove the HDD off the laptop and see if it will get pass the Aptio setup screen because if it does that confirms that its the HDD that is faulty.....not saying this will work for you but please make sure you no what you are doing before you try this.
Nov 06, 2016 | ASUS Computers & Internet
Downloaded Windows 10. Why is pc screen stuck on aotio setup?
Hi there, please try these steps and see if it resolves your issue.
  1. Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable.
  2. Select the Security menu n the Aptio setup utility, select 'secure Boot Control' and change to disable.
  3. Select Save & Exit and press 'yes'.
  4. Hold down the power button until the unit switches power off completely.
  5. Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu.
  6. Select 'Advanced Start Up' and wait until the recovery menu appears.
  7. Select ' Advanced Options'.
  8. Select 'System Restore' and select a date prior to when the problem occurred.
This is for an Asus laptop but even of you are not using an Asus the troubleshooting should be the same. Courtesy of Microsoft customer support. Asus Laptop Stuck in Aptio Setup Utility
Jan 28, 2016 | Computers & Internet
How do I get unstuck from Aptio Setup Utility?
About 5,420 results (0.43 seconds) Search Results
    How to Solve Problems With Aptio Setup Utility - Tom's Guide
    www.tomsguide.com/answers/id.../solve-problem-aptio-setup-utility.html
    Dec 6, 2015 - When I switched on my laptop it shows Aptio setup utility. How do I solve this? ... My Asus is stuck in this mode. The instructions to this seems ...
    ASUS Ultrabook Stuck on/in Aptio Utility Setup - Tom's Guide
    www.tomsguide.com/.../id.../asus-ultrabook-stuck-aptio-utility-setup.htm...
    Nov 14, 2015 - I have an asus si30401u ultrabook that refuses to exit aptio setup utility ive attempted the the fix at ...
    Computer stuck on Aptio setup utility screen. - Microsoft Community
    answers.microsoft.com/...stuck...aptio-setup-utility.../50be23d9-ea0c-483...
    May 17, 2014 - My asus laptop is stuck on the aptio setup utility screen how do I get it back to the start screen.
    Stuck in Aptio Setup Utility - Windows 8 and 8.1 - Geeks to Go!
Jan 05, 2016 | Computers & Internet
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Aug 03, 2014 | ASUS Computers & Internet
Asus v550ca Windows 8 stuck in aptio setup utility
Hi Rick, have you tried Asus support as i believe they may have a resolution to your problem.
Jan 28, 2014 | Computers & Internet
How do I exit Aptio Setup Utility ?
Try running the System Configuration Utility.
- press windows logo + R and type "msconfig"
-go to the startup tab and uncheck the application
-click apply, then ok
-restart your computer
Dec 16, 2013 | Acer Aspire 5100 Notebook
Can not get out of the aptio setup utility screen
if your notebook is a Samsung, just return it back. I had the same problem. samsung service changed my HDD, the problem was seem to be OK. but after 3 h I got my pc from service it crashed again.
Apr 01, 2013 | ASUS Computers & Internet
Computers & Internet Logo
578 people viewed this question
David Payne
David Payne
