Question about HP Pavillion DV6985SE Notebook
HP Pavillion DV6 won't turn on
Hey I have the above notebook and it won't switch on. I left it off for a couple of weeks cause I was clearing my room out and with the holidays and everything. And today I went to switch it on and there was no response. I tried plugging it to an ac source and the power indicator on the side turned on. But, when I pressed the power button, the volume lights goes on, the HP logo and fans go on but just for a about a second and then it goes off. Any ideas what's going on? I tried removing the battery and leaving it with the ac adapter only.
  • Robson Scerri Jan 07, 2013
    Kamlesh; Nothing blinks m8. The HP logo just turns on for a second and then its off again.
  • 57 Answers
If you left it in a dusty place try clearing the dust from the fan outlet to see if that helps
Posted on Jan 08, 2013
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and hp pavilion dv6 ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
Posted on Jan 10, 2013
4 Suggested Answers
  • 55 Answers
SOURCE: Basically i plugged in the
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Posted on Feb 19, 2011
dreamkam
  • 83 Answers
SOURCE: compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
Posted on May 24, 2010
walesarumi
  • 6993 Answers
SOURCE: hp compaq 6715b...dos not turn
Test the adapter with another laptop in other to confirm if truly the adapter is still good. If the adapter works, then it means your laptop is having a power problem.
This has nothing to do with the battery because whether or not the battery is good or bad, that doesn't say the laptop shouldn't work with the adapter.
So the problem as to be either from the laptop's power board or from the AC adapter.
Tale care.
Posted on Aug 26, 2010
Hp pavillion dv6 on but dark screen
sounds like the black screen of death
a lot of dv hp laptop have this problem the gpu has to reflowed are your keys also blinking. if they are count the number of blinks it will point to problem
HP DV7 Laptop Graphics Fix Black Screen of Death
would not fix it his way
Jul 04, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
Henches problem in hp pevilion dv6
Chandanipraj,
1) Hinges example,
http://www.ebay.com/itm/New-LCD-CCFL-Screen-Hinge-Set-Left-Right-for-Hp-Pavilion-DV6-15-6-Series-USA-/261104644529?pt=US_Laptop_Screens_LCD_Panels&hash=item3ccb0cb1b1
2) HP Support > Pavilion dv6-1050us Notebook PC > Main Supoort page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860586&lc=en&cc=us&dlc=en&lang=en&cc=us
Manuals >
Click on -
HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
It's a Service Manual,
Pictorial guide in replacing the LCD screen, and also replacing Hinges,
http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/
Just to add;
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
For additional questions please post in a Comment.
Regards,
joecoolvette
(Hi from the USA)
Oct 18, 2012 | HP Pavilion dv6-1050us Notebook
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Hp pavillion dv6-2155dx keeps buffering and won't play videos correctly
Are you connecting wireless or wired connection. Have you updated your flash player? Which browser are you using? Do you keep your computer cleaned up from internet browsing? If your browser is up to date and so it your flash player then more than likely it could be the internet connection. If you are running it wireless try plugging it in to the router with a cable and check it. Another thing would be to check for a virus.
Jan 31, 2012 | HP Computers & Internet
Not being able to connect on my wireless computer I ran Diagnostics and it said the wireless is off.I have no idea how to turn it back on.It is a HP Pavillion dv6-1030us PC notebook
I suppose it could be something as simple as the switch was turned off by accident. On my laptop, there is a small slide switch below the front edge. It is easy to move it, you may have done so moving the laptop or whatever. Look for it, there should be a small yellowish light come on when the wireless is on.
Aug 10, 2010 | HP Pavilion dv6-1030us Notebook
Hp pavillion dv6 laptop no power
1. Check the adapter
2. Check the processor
3. Check the motherboard if defective replace new one.
Note: You need to know the right spare part number of your motherboard e.i 443776-001. Here's a sample video
May 04, 2010 | HP Pavilion DV6500Z Notebook
Hey My touch panel aint working
there is a button at the top of the touch pad with a light to the left, blue means its unlocked, orange means its unlocked. try the button to swap between states
Jan 12, 2010 | HP Pavilion dv6000t 15.4" Notebook Laptop...
I need de manual of de HP Pavillion dv6 1245dx
you can download it by clicking on the link below:
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Nov 08, 2009 | HP Computers & Internet
HP Pavillion DV6985SE Notebook Logo
201 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
