Question about Dishwashers
Blocked diplomat dishwasher! Fills with water and doesn't drain again.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Theres a hose that goes from the dishwasher to the sink see if the hose is full of junk
Posted on Jan 07, 2013
  • 221 Answers
SOURCE: GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Posted on Mar 16, 2009
  • 883 Answers
SOURCE: Sears Kenmore dishwasher drains and then fills back up.
you have a nearly-clogged u-tube near the connection to your house drain piping. clear the clog out.
Posted on May 31, 2007
  • 16 Answers
SOURCE: Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Posted on Feb 10, 2008
rickzilla
  • 706 Answers
SOURCE: i have a integral dishwasher
Hello wayne180764,
If the wash arm ( impeller ) is free to move, then chance are the motor that dirves it isbound up or defective. IT may be trying to spin ( the humming noise) but unable to ( for whatever reason).. and then shuts down from overtemp or overcurrent sensors on motor.. If you want to diagnose the parts further..please use this link which includes some additional information
http://www.haier.com/admin/en/product/upload/ADP8352-UM.pdf
Regards,
Rick
Posted on Dec 13, 2008
SOURCE: candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Posted on May 02, 2010
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
Modle diplomat aca 9102 dirty water does not drain from dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | Dishwashers
When I try to drain my dishwasher, it fills up my sink. when the sink drains, my dishwasher fills
Sounds like you have your dishwasher drain connected directly to your drain under sink and you have a blocked drain. It will function normally once you have removed the block in the sink drain but you should have a the dishwasher drain hose hooked up to a air gap to prevent harmful bacteria from getting in to the dishwasher again in the future. Hope this helps.
May 29, 2011 | Dishwashers
My diplomat dishwasher wont drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 21, 2009 | Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Dishwasher filling
check to see if you have anything plugged
Mar 26, 2008 | Dishwashers
Will not Complete a Wash Cycle
hello.
Please consider examine the control panel and the circuit of the machine maybe some connection setting is lessen.
melnavz
Mar 18, 2008 | Dishwashers
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
163 people viewed this question
Top Dishwashers Experts
