Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Echo CS8000 keeps burning up spark plugs
I have an Echo CS8000 that will run for 45 minutes to an hour then it burns the spark plug up (it does not foul it actually burns up)
This happened two times and now the saw will not even attempt to fire.The saw just had a new intake boot installed on it and the carb. rebuilt on it about three weeks ago.
I just purchased the saw from an individual and when I went to check it out the saw fired up and ran great so I bought it but after 45 minutes run time under load the problems started showing up.
Has anyone else had this problem or does anyone have any ideas on how to fix it ?
I'm not a small engine mechanic but it kinda sounds like its running to lean, not sure if there the same but if 4 cycle engines run way to lean they detonate and can melt a piston. Most of the time they will run fine under no load but once under load it will cause the detonation. If you have a compreesion gauge see if it has any compression if you dont have a gauge just put a finger over the spark plug hole and pull the starter to see if it builds any compression, if no compression probably a hole in the piston or bore hope this helps
Posted on Feb 22, 2009
17 hp kubota burns out right side spark plug in in an hour, not filed just dead will not work on the other side if switched after burned out. What can cause that?
Hi Robert:
Sounds like you've some trouble shooting to do. Try starting by installing new spark plugs in all cylinders. Find a project and run the machine for an hour or so. Let it cool off, then pull the spark plugs. Keep track of which one is from each cylinder. There are some excellent charts available that show what is going on in an engine from the appearance of the plug. OILY & Fouled is usually bad rings, SOOTY black can be too rich a mixture, Too lean can make the tip look almost melted. Enjoy the chase!
Mar 03, 2015 | Kubota Garden
KX60 stator coil values, keeps popping spark plug
burn out silencer packing or exaust leaks can burn a sparkplug , i guess your exaust system have lots of leaks that make the sparkplug fool and burn
Dec 18, 2013 | 2003 kawasaki KX 250
My spark plugs keep burning out on my lucida petrol and it runs on gas year of car is a 96
This is the problem its running on propane which will burn the plugs out quicker than petrol you could try a hotter grade of spark plug though or them bosch one with the three electrodes but in all honesty on propane gas they will burn
Oct 02, 2013 | Toyota Cars & Trucks
Sparkplugs keep burning
It maybe burning too lean,the O2 sensor and coolant temp sensor may need to be replaced to correct the problem,if the cat(converter) is not stopping up.
Spark plug keeps burning out
getting it wet w/ anything makes the sparkplug busted,or its not compatible w/ the cdi .
Apr 03, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Keeps burning spark plugs and wont stay running
First, check you are using the correct plug, if you are using one that is too "Cold" it will burn out and cause running problems. If the plug is too "Hot" it can cause holing of the piston and erratic running. It could also be a mixture problem (fuel/oil) but try the plug first.
Aug 01, 2012 | Yamaha Motorcycles
What should I do with my husqvarna 130BT because I put in too much oil with the gas and it won't start?
First, you need to dump all of the fuel out of the gas tank, Preferrably into a gas container. If you know how much oil you dumped in, you can calculate how much more gas to add. You could also just dump the gas, re-mix some new gas and oil, whichever you prefer.
If you are comfortable doing this, remove the fuel lines going to the carberator and let them drain into a pan. Pump the fuel primer to purge the gas out of the carburator, and then re-install the fuel lines. This might help you get it started a little faster, but its not necessary. You can burn the old gas in the engine at it will be fine.
Next, remove and replace the spark plug. Its probably fowled out with too much oil. Keep a can of carb cleaner and a small wire brush handy, you may need to clean the spark plug a couple times. If it gets too dirty, you can replace the spark plug with a new one. Do not burn Carb Cleaner in your engine for long periods of time, it will damage the engine.
After you have installed the spark plug and put some correctly mixed gas in the tank, Try to start the engine again. There will be some residual fuel in the fuel lines going to the carberator, so you will need to burn off that gas.
If you can't get it to start, try these steps:
Choke off, throttle wide open, crank several times. (or let it sit in the sun for a couple hours) (this corrects flooding)
Prime carberatur, Choke full on, throddle idle position, crank until it fires once but does not start.
Choke half, crank until it fires again or starts.
If it starts skip this step: (Choke off, crank until it starts).
Keep the choke on half for about 10 seconds and let it idle.
Put the choke off and let the engine warm up for a couple minutes.
After warmup, test the throttle to see if it will run at full throttle (it may take some fluttering until the engine is fully warmed up)
Let the engine run at full throttle for a few minutes. The exhaust may be a little more blue-smokey than normal...this is the excess oil burning...totally normal and harmless.
Mar 25, 2012 | Husqvarna Garden
Oil collecting in exhast, and running out on floor, saw won't fire, has been running good ,i have an echo md.#302...help
Try putting a new spark plug in it.Check your gas and oil mix.you might have too much oil in gas this will cause the oil to leak out the exhaust because it will not burn off the excess.
Nov 29, 2010 | Echo Garden
Engine will not run but a few minutes at a time
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Jun 01, 2010 | Honda Pressure Washer PSI 3000
2003 Impala 3.4 missing/dying
1 Inspect Timing Belt SlipPED or Broken Timing Belt. 2 Inspect Timing Chain SlipPED Timing Chain. 3 Inspect Timing Set SlipPED Timing Chain or Worn Timing Gear(s). 4 Inspect Fuel Injector Dirty or Worn Fuel Injectors, or Vacuum Leak in Fuel Injection System. 5 Inspect Carburetor Incorrect Carburetor Adjustment, or Vacuum Leak at Carburetor. 6 Inspect NEEDLE Seat Dirty, Worn, or Damaged Carburetor NEEDLE and Seat. 8 Inspect Timing Specification Incorrect Ignition Timing. 9 Inspect PCV Valve Clogged Emission System. 10 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 11 Inspect Distributor Cap Distributor Cap Cracked or Burned. 12 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s). 13 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 14 Inspect Crankshaft Gear Worn Timing Gear(s). 15 Inspect Camshaft Gear Worn Timing Gear(s). 16 Inspect Distributor Cap and Rotor Kit Distributor Cap Cracked or Burned. 17 Inspect Valve Burned, Worn, or Sticking Exhaust Valves. 18 Inspect Camshaft Worn Camshaft LOBE(s). 19 Inspect Valve Lifter WornValve Lifter(s). 20 Inspect Belt Incorrectly Routed, Adjusted(Tensioned), Missing or Worn Drive Belt(s). 21 Inspect Alternator Low or No Voltage OUTPUT From Alternator/Voltage Regulator. 22 Inspect Voltage Regulator Faulty, Shorted or Incorrectly Connected Voltage Regulator. 23 Inspect Relay - Charge Lampat Damaged or Faulty Charging Relay.
Aug 31, 2009 | 2003 Chevrolet Impala
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
409 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
