Question about HP Photosmart 2575 All-In-One InkJet Printer
Scanning problem My scanner asks me to install/run device for feature evertime i click the scan button
    Genius:
  • 2,985 Answers
Remove the software. Unplug the USB to printer Restart the Computer. Reinstall the software- do exactly as it says- it will ask you to disable A/V software- come off line and do that. It will say [maybe] do not plug device in until told- unplug and do that. Do it right.
Posted on Jun 30, 2007
Hi, i have a canoscan lide 25, it's installed, but when push the scan button, nothing happens. but when i open control panel and click test scanner, it works and makes sounds and says test is complete.
What is your OS? Do you have the full featured software installed and set up (TWAIN driver plus the Toolbox including ScanGear CS )? Do you mean the software scan button or the hardware (on the scanner) button?
If you are trying to launch a scan from the scanner, then scan button will only work if the computer has the full software and is running the monitoring program. You also need the default destinations in the software. These are the standard resolution for the scan and the folder to save the resulting file among other things. The full software is available for supported OS versions here: http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25?selectedName=DriversAndSoftware#DriversAndSoftware . Test scanning from the computer software as well.
If the problem is at the software on your computer, try a new data cable. If you are using a USB hub, try a direct connection. Scanners require bi-directional communication with the computer and will fail if there is any damage to the USB port, driver or cable. If you can, try a different USB port. If problems persist, disconnect the data cable between the computer and the scanner. Uninstall the Canon software and the driver. Then reinstall and try scanning again. (For Windows OS versions, check the Device Manager to make sure that your USB driver is working. Click Start > Control Panel > Hardware (title varies with version) > Device Manager. If you see a triangle with a red X or yellow exclamation point, try updating the driver.)
I hope this helps.
Aug 15, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I have downloaded my software for my hp officejet 5510v all-in-one and my scanner part will not work. I have 3 in one--print--does o.k., fax does good some times, will not scan---please help
Is the scanner installed correctly? Full feature software is that what you have installed?
try starting mspaint and test scanning
start -> run -> type in mspaint click ok
Then file and from scanner or camera, follow instructions to scan,
Sep 10, 2008 | HP Office Equipment & Supplies
Tip
Windows 7 and HP scanjet 8250, 8200, 8270; front panel buttons and searchable...
How to install a HP scanjet 8250 in windows 7 with full features like double side scans and searchable PDF creator.
The basic driver automatically installs with windows 7.
The basic driver lets you scan one page at a time and does not let you do advanced options like double side and creating searchable PDF's.
HP has a software package listed for the HP 8270 scanjet that works properly with the 8250 scanner. I would assume that any scanner in the 8200 series would work with this software.
For full scanning features, I installed the HP photoshop essentials and the HP solution center. Find the download here, on HP's web site.... http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1118286&prodTypeId=15179&prodSeriesId=1118292&swLang=8&taskId=135&swEnvOID=4062
Click on the software link .."HP scanjet Full Feature Software and Driver"
After the install run the setup and follow the directions,
After the install, the front panel buttons on the scanner should now work. You should also be able to create PDF's(searchable) with the one touch of the scanner button.
on Jan 28, 2010 | Computers & Internet
I bought a new hp computer with Windows 7 OS. My hp Officejet 7310 now will not scan. The HP Solution Center that was downloaded with the HP Officejet All-in-One series Windows 7 driver disc (new, just...
A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. You can print from a software program, and import and view images on a memory card, if your product has a memory card slot. With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. How to Scan a Document in Windows 7 By Greg Harvey The Windows Fax and Scan utility enables you to scan documents and pictures. Before you can scan documents and pictures, you must have a scanner installed on your computer. Your scanner must be listed in the Devices section of the Devices and Printers Control Panel window.
To check to see if your scanner is properly installed, open the Device Stage. Choose Start?Devices and Printers. If Windows doesn't automatically find your scanner, you can manually add it in the Devices and Printers window by clicking the Add a Device button in the toolbar and following the wizard's commands.
  1. Choose Start?All Programs?Windows Fax and Scan.
    Windows 7 opens the Windows Fax and Scan window.
  2. Click the Scan button in the Navigation pane, then click the New Scan button on the toolbar.
    The New Scan dialog box for your scanner opens.
  3. Use the settings on the right to describe your scan.
    By letting the computer know what you're scanning, its color profile, and the type of file you plan to create, you enable Windows Fax and Scan to create the highest quality scan.
  4. Click the Preview button to see what your document will look like.
    Make any last minute changes.
  5. If you're happy with the preview, click the Scan button.
    Windows scans the document and presents you with an image of your document.
  6. Click the Save As button and complete the necessary information.
    Enter the filename, the type of graphics file you want saved, and then click the Save button.
To automatically forward the document you've just scanned as an attachment to a new fax message, click the Forward as Fax button.
The scan feature in the Windows Fax and Scan utility is set primarily to scan text documents. If you want to scan a photograph or other graphic, you're better off doing that directly within the Windows Live Photo Gallery.
Read more: http://www.dummies.com/how-to/content/how-to-scan-a-document-in-windows-7.html#ixzz15JFYWJQ1
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2010 | Computers & Internet
I DONT KNOW HOW THE SCANNER WORKS.WHERE TO INSERT THE PICTURE I WANT TO SCAN.
Which device do you have? If it is an all-in-one that does not have an automatic document feeder (ADF), you lift up the scanner cover and place your photo face down on the glass. If there is an ADF, place the document face up in the feeder. (Using the ADF is not recommended for pictures.)
If it is a stand-alone scanner, the cover is more obvious. For single-sheet scanners, check the manual for which side of the document needs to be forward.
Depending on the OS and software installed, you launch your scan program and adjust the resolution and destination and press scan. (If you have an all-in-one, you may need to install the manufacturer's full-featured software first. Otherwise you will only get printing enabled.) If you use a generic OS driver, the buttons on the unit will not trigger the computer responding to the commands.
Set the destinations for scanner buttons in the software before using the unit buttons when using the full-featured software. Check the manual for specific information. The button presses are noticed by a monitoring program. If that isn't running the unit buttons will not work.
I hope this helps.
(Windows XP, Vista and Win7 all accept scans in Paint (File > Import from Camera or Scanner > New Scan). Vista and Win7 also have Windows Fax and Scan that can acquire scans.)
Sep 14, 2010 | Office Equipment & Supplies
How do i scan documents onto my comp
It depends a bit on the software you have installed (OS, etc). If you installed the full-featured software before connecting the all-in-one to your computer, you can scan immediately from the computer. For Windows, open the HP Solution Center (by double-clicking on the icon or Start > All Programs > HP folder > HP Solution Center). Put your document to be scanned face down on the scanner glass and close the lid (ADF pages go face up, top edge first). Click the tab in the Solution Center for your HP product (if you have more than one) and click Scan Picture or Scan Document as appropriate. Set the scanner settings in the pop-up window if needed. Click Scan to start the scan. To use the buttons on the scanner, you need to set the destinations for the buttons in the HP Solution Center (Scan to destination for example) and have the HP monitor running on your computer (this listens to the buttons).
Scanners work with bi-directional communication so USB hubs, print servers or bad cables can result in the printer functions working but not the scanner.
If you install the generic OS driver (by connecting the all in one to the computer before installing the software), the printer will work but the scanner will functions will be limited (the scanner buttons will not work but other functions will depend on the OS). Windows XP can acquire scans in Paint (File > From Camera or Scanner). Windows Vista and Win7 add Windows Fax and Scan which will also acquire scans (not in all versions of Vista). Vista also can acquire scans with Windows Photo Gallery.
The printer works similarly with the Mac OS but hte names may be different.
I hope this helps.
Jun 14, 2010 | HP DeskJet F4280 All In One Printer InkJet
Can't scan with my HP officejet 4255 all-in-one
Hi
Hope you doing well this year and i am sure that thing will go good as well
the problem you mentioned : When you press the Scan button on the product control panel, nothing happens. A scan does not start.
This issue usually occurs because you do not have the full feature driver installed for the product. Button functions on the product control panel require a full feature software and driver installation for Windows Vista.
Follow these steps to download and install the full feature software from the HP Web site.
1) Turn the product on.
2) Disconnect any USB cable from both the product and the computer.
3) Open a new window to browse to the Select Software and Drivers page:
Click on the Following Link to get the Updated drivers for all OS
DRIVERS HP Officejet 4255
4) Click / select the Operating system
5) Click the Full Feature Software and Drivers option.
6) Click Download only . This option allows you to install the software at any time after the download completes.
7) Click Save , and then browse to the location on your computer where you want to save the file.
8) Click Save . The software downloads to your computer.
Tip: Make a note of the place that you saved the file, in case you want to install it at a later time.
9) When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe .
10) You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
11) When the Install Wizard starts, follow the on-screen instructions to install the software.
Method of Scanning with Windows Photo Gallery
To scan a document using Windows Photo Gallery in Windows Vista, follow these steps:
1. Click the Windows Vista ( ) icon, click All Programs , and then click Windows Photo Gallery .
2. Click File , and then click Import From Camera or Scanner .
3. Click Import , and then click Scan .
Method of Scanning with Paint
To scan a document using Paint in Windows Vista , follow these steps:
1. Click the Windows Vista ( ) icon, click All Programs , click Accessories , and then click Paint .
3. Make any desired setting changes, and then click Scan .
Method of Scan using Windows Fax and Scan
The Windows Fax and Scan option is only available in the Business, Ultimate, and Enterprise editions of Windows Vista.
1. Click the Windows icon ( ), click Programs , and then click Windows Fax and Scan .
2. Click New scan .
3. Click File , and then click Scan .
Enjoy your new year
Cheers
Tejodhar Atreya
Jan 04, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
When trying to scan, 7210 doesn't see/recognize networked computers
From each computer, you need to run the HP Director. When opened, click on SETTINGS, then SCAN TO settings to configure. This way it will transfer data to the scanner so that when at the scanner, that computer will be in the list of places to send a scan job.
Jul 25, 2008 | HP Officejet 7210 All-In-One InkJet...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
19 people viewed this question
Clive
Clive
