Question about Canon CanoScan LiDE 500F Flatbed Scanner
Can't get this scanner to work. Keep getting this message. Release the lock switch, detatch the I/F cable and reconnect. Scanner driver will be closed. I have no idea what ANY of these mean. I have downloaded the driver for Windows XP, but it still won't work. I keep getting this message. Any bright ideas what I should do? Thanks!
3 Suggested Answers
SOURCE: errow msg. "release lock switch and detatch the i/f cable" still will not scan.
There is a switch on the underside on the scanner. This is the lock switch. Flipping it should solve your problem.
Posted on Jun 22, 2009
  • 10 Answers
SOURCE: I keep getting a message that says, release the
Close the scanner driver and return the scanner to your overlord. Your virgin child will be sent to you immediately.
Posted on Mar 17, 2010
Ezrahite
  • 2632 Answers
SOURCE: Error Message on Canon Scanner
Welcome to Fixya. I provided below the link for the resolution below. It explains why you have the error and the solution ot fix it.
Error Message Fix
Thanks
Posted on May 11, 2011
Hello I am having problems saving my documents I am receiving an error message "Release the lock switch,detach usb cable and reconnect.Close the scanner driver .What lock switch is this ?please advice...
-is this a new scanner? is this the first time you are trying to scan?
if you answer yes to any of this questions, please check underneath the scanner, find the latch to release the scanning head.
Dec 16, 2010 | Canon CanoScan D646U Flatbed Scanner
I keep getting a message that says, release the lock switch, detach the I/F cable and reconnect. Scanner driver will be closed
Mar 17, 2010 | Canon Office Equipment & Supplies
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Jan 11, 2010 | Visioneer OneTouch 7100 Flatbed Scanner
Message received Release the lock switch,detach the usb cable and reconnect. Tried this but it doesn't work. The scanner is not locked!
Uninstalled software, disconnected usb cable. Then reinstalled software and reconnected usb cable.
All up and running!
Nov 23, 2009 | Canon Office Equipment & Supplies
Errow msg. "release lock switch and detatch the i/f cable" still will not scan.
May 26, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canon CanoScan LiDE 500F Flatbed Scanner Logo
89 people viewed this question
old marine
old marine
Corne Viljoen
