Question about Canon iR 2016i Black and White Copier
COPIER IR 2000 SYSTEM ERROR E100 - Canon iR 2016i Black and White Copier
    Problem Solver:
  • 18 Answers
Check the drum unit or laser connection or clean the pantagon
Posted on Mar 14, 2013
5 Suggested Answers
  • 18 Answers
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
SOURCE: there is error code e100
e000024-0001
Posted on May 16, 2011
SOURCE: how do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Posted on Dec 14, 2011
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
Dec 14, 2011 | Canon Office Equipment & Supplies
I have a problem of system error of copier ir 2000. how can i solve it?
can You be specific by mean of which system error? Like E100? E000?, E001....
Few examples of most common errors:
E100 - Laser trouble - change the drum unit ( complete drum unit )
E000/001 - fixing trouble - try to reset the error under service mode - procedure: press MENU and #, with > key go to CLEAR and OK, find ERR and OK, turn off and back on - if it helps you solved the problem, if not you need to change the thermistors or the fixing lamp, because you have low/high temperature problem.
E019 - waste toner full - remove the drum unit and open the corks on top of the unit and empty/vacume waste toner out.
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
There is error code e100 in cannon photo copier ir 2000
replace drumunit ,if it persists replace laser unit
Jan 07, 2011 | Canon imageRUNNER 2000 Copier
hi there
Jul 15, 2009 | Canon iR 2016i Black and White Copier
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Ir 2010
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Sep 28, 2008 | Canon iR 2016i Black and White Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon iR 2016i Black and White Copier Logo
old marine
old marine
