Question about Juicers
Lid of machine needs fixing or replacing
Black plastic bit on the blade in the lid has come off. I am looking for a replacement lid or someone who can fix it.
2 Suggested Answers
SOURCE: How does the flat blade
you may check this link to help you the step by step instructions in putting the flat blade thru its manual
http://waringproducts.com/ret/share/man/29_man.pdf
Thanks..
Posted on Nov 04, 2010
We're can I get a replacement lid for my Bella Sendio juice extractor model 13694a
Fixya does not sell replacement lids and cannot advise sources.
Aug 05, 2017 | Juicers
I need to replace the shredder blade on my big boss juicer, where can i get a replacement?
Where can I find a replacement top lid for my Big Boss Juicer? I have been looking all over online but still have not had any luck. Thanks! -Danielle
Jan 26, 2012 | Juicers
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
My Omega Juicer 1000 shakes violently and the entire machine rotates unless I firmly hold it or turn it off. It's been in the closet for good seven years before I took it out and started using it. It's...
Make sure the bottom of the feed chute is not damaged. If it,s chipped or scored, try filing
it down level as best you can. Then with the juicer fully assembled, unlock the set screw
on the center of the bottom and turn it clockwise until the chute contacts the blade, then
back it off a half turn and lock it down. By the way a dull worn blade will produce less
vibration. I'm assuming the lid is plastic.
Sep 28, 2010 | Omega 1000 Juice Extractor
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Repair or replacement of Power juicer
The part has a lifetime warranty. Just call the customer care line at 1-973-287-5150 and give them your model number. You have to pay shipping though. Our shipping cost was about $26.
Sep 13, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
