Question about Olympus VN-4100PC Digital Voice Recorder
Record only part of file
Hi I have down loaded all files but now want to edit and record only a few minuites of each file to seperate folder ?????????
Ideas gratefully accepted
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Can not edit with the digital wave player software, but programs such as audacity or wavepad should be able to accomplish this
Posted on Jan 20, 2009
80070246 error when trying to update windows how to fix problem
Clear the contents of the WindowsUpdate folder
  1. Click Start, click Programs, and then click Windows Explorer.
  2. In the left pane, double-click the Program Files folder.
  3. In the left pane, double-click the WindowsUpdate folder.
  4. In the right pane, click the V4 folder, click Edit, and then click Invert Selection.
  5. Press DELETE, and then click Yes to confirm.
  6. Open the V4 folder, then in the right pane, click to select the IUHIST.XML file, click Edit, and then click Invert Selection.
  7. Press DELETE, and then click Yes to confirm.
Note When you delete the IUHIST.XML file from the WindowsUpdate folder, you clear the whole Windows Update installation history. Microsoft does not recommend that you do this because you lose your record of previous downloads. The steps in this section delete all your files except the IUHIST.XML file.
Apr 04, 2010 | HP Pavillion ZV6000 Notebook
How do i record something and make it a ring tone
After your sound recording, go to your record folder and then open the recorded sound and then option and set it as a ring tone.
Oct 29, 2009 | LG Vu CU920 Cellular Phone
Bizarre
Try Browsing the folders I Hope your footage is in one of those folders.
To Make It easier Goto Folder options click detail for folder check dates for the shooting time & open those 1st also if the camcorders timer is not set right may look in folders day earlier. Also look for big files Dvd takes lot of space.
Belive you are not being given chance to record or finalize becuse camcorder automaticaly did so. Rarely but it happens when a disk will have errors on it & when it finalzies you can lose info/footage.
Why I still prefer tape.
Mar 08, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony ICD-UX70/UX80 digital recorder...memory full problem
If you press and hold down the "menu" button scroll down to the FORMAT selection and press enter. This will reformat the device.
I had the same problem - I think it arose after disconnecting the IC Recorder when it became unresponsive with the computer.
Make sure you transfer all your files first to a computer or back up source.
Nov 19, 2008 | Sony ICD-MX20 Digital Voice Recorder
How do you edit a recording on an Olympus DS-30 dictatation machine. All I want to do is record over what I have dictated but the machine just creates a new file everytime I press the record button again....
Unfortunately with this recorder it is not possible to edit over a previously recorded file. Each time you hit record and then stop it will create a new file each time. That's the way the recorder is designed. If you need to be able to stay within the same file you may want to check out the DS-2300 or the DS-2400 as it has a NEW button on it that allows you to stay within the same file until you press NEW to start a new file.
Aug 05, 2008 | Olympus Computers & Internet
How do I delete certain files from my Sansa?
try going to "my computer" then scroll down until you see an icon that says Sansa e250 click on that then search through both files(2 folders should come up one says data and another says media) try finding the source in here
May 06, 2008 | SanDisk Sansa e250 MP3 Player
Not showing video
Try This;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 27, 2007 | SanDisk Sansa e250 MP3 Player
Olympus DS-50
No, you can't do this on the Olympus DS-50 , its not a dictation machine, you can do this only by Olympus DS-2300, DS-3300, & DS-4000 which they have the Editing Features : Insert,Overwrite, eraseing and Partial erase
Oct 26, 2007 | Olympus DS-50 Digital Voice Recorder
Will not down load on Mirosoft Vista Platfrom...
Vista compatible software can be downloaded here:
http://downloads.olympus-europa.com/consumer/VoiceRecorder/720/eng_2000_xp.zip
After installing the software you need to install following updates
http://www.olympusamerica.com/files/DWPUP4EN.zip
http://www.olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
The software will work with the 32 bit edition of win Vista, not with the 64 bit edition.
Oct 21, 2007 | Olympus VN-960PC
Olympus VN-4100PC  Digital Voice Recorder Logo
93 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
