Question about Radio Communications
Can't hear cisco ip communicator on gn2000 headset
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
SOURCE: VOIP headset PlantroMX500i 72517-01 to use with Cisco IP spa504G
mx500i.gif MX500i 3-in-1 VoIP Headset Sorry your headset + phone combination is not currently listed in our database. Please contact Plantronics Technical Assistance Center to confirm compatbility
Versatile 3-in-1 Headset for Internet/VoIP, cordless and mobile calls
Part Number: 72517-01
Posted on Jul 22, 2010
wb91
  • 126 Answers
SOURCE: i connected my S11 plantronics
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Posted on Jun 03, 2011
HDI Headsets
  • 537 Answers
SOURCE: i have plantronics cs 70 and this is connected to
You need to check all the locations of the dials and #'s, sometimes it is just a simple matter of turning a dial. Here is a link to the CS70 User's Guide that may help you.
Good luck from Headsets Direct!
Posted on Sep 15, 2011
HDI Headsets
  • 537 Answers
SOURCE: i can't hear the other
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Posted on Sep 21, 2011
Cisco 7972 use headset
You can use a standard PC or cell phone headsets with Cisco phones. With help of our adapters, you can convert computer headset, smartphone headset or cordless phone hands-free into Cisco compatible headset.
Cisco IP Phones
Feb 06, 2014 | Cisco Computers & Internet
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
Jan 08, 2014 | Cisco Computers & Internet
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco: http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a00809b6c40.shtml
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
I have a CISCO IP communicator phone and a logitech h800 phone. I can't pick up and end calls
I know this is a bit late answer, but i got these headphones a few days ago and found a solution for it :)
You can check my post here:
http://www.autohotkey.com/board/topic/90056-hotkey-logitech-h800-with-cisco-ip-communicator/
Good luck! :)
Apr 13, 2012 | Logitech H800 Wireless Headset Microphone...
I have plantronics cs 70 and this is connected to my cisco ip phone .the problem is i can't hear the other person on my phone but other persons can hear me ok.
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When I call people hear me but I cannot hear them
Using the Cisco IP soft phone via VPN can sometimes cause audio to drop. To fix this:
Right click the Cisco IP Phone and select Preferences...
Select the Audio tab
Click on the Network button
In Audio IP Address select Use this address
then set it back to Detect Automatically
Click OK and OK again.
Give it 5-10 seconds and this will auto reset the audio on the IP phone and will correct the issues with one way audio.
Jun 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Using Cisco IP Communicator- works to call out & receive calls, but I can hear them-they can't hear me. Also have 3 question marks next to headset icon at the bottom - headset has been tested &...
One way communication is usually a routing issue. Make sure that you have two-way routing to and from the subnets that are trying to contact you... could also be the reason why you have the question mark on the buttons too.
Hope this helps!
Jun 05, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Apr 21, 2010 | Radio Communications
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
Oct 28, 2008 | Jabra T5330 Wireless Headset
Radio Communications Logo
60 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
