Question about Linksys A+G WRT55AG Wireless Router
Getting better signal quality on wireless network?
I just purchased a linksys wireless router and usb network adapter. everything's working, but i'm wondering why the signal quality is so low. the room that i have it in is maybe 40 feet away at most. I have made sure that the usb adapter is on top of the computer, and that the router is on the desk of the other computer so that there isn't any interference. Are there any settings i should change on my computer or the adapter?
  • 432 Answers
Under the tab 'wireless' find the strint that says 'Channels', and change to another one (anyone) and then give it a day to see if you lose connection, if you do, go back and change it again. Try downloading the latest drivers and software. The WRT55AG and WRT54AG are known to drop signals. These routers are like cell phones, you have to find a good spot for them.
Posted on Jun 30, 2007
SOURCE:
I just set up a wireless network in my house. My config is this Verizon Fios ONT running ethernet Linksys gigabit 8 port switch 150 foot length of cat 6 running to my verizon router from switch 50...
Try disabling the onboard wireless adapter- the two may be conflicting w/ each other. The other thing I can think of is try a system that does NOT have wireless onboard (a desktop for instance)- that way you could see if the issue is indeed the internal connection's broadcast interfering with the usb adapter
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Feb 01, 2011 | Cisco Linksys AE1000 High Performance...
The router often looses wi-fi signal and dhcp gives wrong address ( exemple: 169.164.....)
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
    Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
  • Customizing Wireless Settings of the Router
    Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
    1)To change the router's SSID or the wireless network's name, click here.
    2)To change the router's channel, click here.
    3)To enable the wireless security on the router, click here.
    NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
Dec 14, 2010 | Linksys WRT120N Router
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Dec 13, 2009 | Belkin Computers & Internet
Cannot get my USB wireless-G adapter to work
hi mark, if the wieless G is already installed don install the linksys cd,  in ur working computer go to the lynksis page and set the wireless to manual and to channel 9 then in the non working computer  open the wireless g utility and look for options such as let this tool mange wireless if ticked uncheck it, or let windows manage wireless check the option close that box then start-control panel-network connection-wireless network connection-right click on it -view avail wireless networks and slect ur network and click to connect enter the wireless key and u will be connected to internet
Oct 31, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
Wireless Network
You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
Hope that helps........
Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Signal strength
An omni directional antenna connected to the router will extend the range of your wireless network, it should solve your problem. You can find them in any PCs store.
Nov 30, 2007 | Linksys WUSB54GS 802.11G USB Adapter...
Open Questions:
AOL DESKTOP GOLD isntallation error #@ {1844641-OO35} pHoNe nUmBeR SAKTE USA AOL DESKTOP GOLD can't open linkAOL DESKTOP GOLD not working pHoNe nUmBeR {+184464I-OO35} to resolve all AOL DESKTOP GOLD email products. JCG is an American multinational company which was founded by Michael AOL DESKTOP GOLD email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AOL DESKTOP GOLD email support number, and selling of computer-related services and products. AOL DESKTOP GOLD email Tech Support Phone Number Recently, AOL DESKTOP GOLD email has been named the number AOL DESKTOP GOLD email technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AOL DESKTOP GOLD email customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a AOL DESKTOP GOLD email Service Tag or a AOL DESKTOP GOLD email Get AOL DESKTOP GOLD email Technical Support Phone Number and Customer Services. AOL DESKTOP GOLD email is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
Aug 17, 2019 | AOL Computers & Internet
See all Linksys A+G WRT55AG Wireless Router Questions
Linksys A+G WRT55AG Wireless Router Logo
164 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
