Question about Envision Monitors L26W761 26 in. LCD HDTV
How do you hook up a DVD player to the TV and what do you program the TV to, to play the DVD?
What inputs and outputs do I use on both the TV and the player.....and what does the TV get programmed to see the movie?
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I can play dvds but not vhs. how do i hook it up or program it, etc, so I can watch vhs?
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
Apr 27, 2010 | JVC HR-XVC19S DVD Player/VCR
I need to connect my Panasonic DMR-E85H DVD to an old HMV TV. I need to know what the frequency of the out pout would be for the A1, A2, A3 output channels from the DVD and what the input frequencies...
It doesn't use TV channels, it uses AV, Audio Visual, input. That means you hook up, to the, whats called the EXTERNAL Inputs, A1, A2, A3, these are the external inputs that relate to the Jacks on the rear/side of the unit. You use the output from the DVD, and hook it up to the AV input on TV. Press Play on DVD and Select, correct external input on TV. Usually it;s Yellow to Yellow Red to Red and White to White.
Mar 02, 2010 | Panasonic DMR-E85H DVD Recorder
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Envision Monitors L26W761 26 in. LCD  HDTV Logo
20 people viewed this question
Top Envision Televison & Video Experts
bigdawg7299
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
