Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Smoking Fan Assisted Oven
Oven Smokes badly have thoroughly clean oven removing all shelves have check fan and elements for grease, but still smokes badly at 160 and above. We used Mr Muscle Oven cleaner. Pls Pls HEPL !!! (not Stainless steel, but Black)
  • begreen9 Feb 25, 2009
    We are getting a plastic smoke smell from our new Electrolux wall oven. It is overpowering and intense. We are not meat eaters so this is not from meat fat or splatters. The whole house filled up with this smoke today when my wife tried to broil for the first time. What is this and how do we fix?
  • 979 Answers
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
Posted on Feb 11, 2009
Why is this model smoking so much when you use the oven why is so hard to clean the upper part the element is in the way and it is almost impossible to clean it
smoking ovens is from burnt on grease where people do not use oven bags to prevent grease spatter
get advice on how to remove the element and replace with a new one ( grease free) use a good quality spray on oven cleaner and let stand for the directed time then clean out properly refit the new element
it will be best if you remove the door first as it makes it easier to get in the oven
May 21, 2015 | Ovens
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
Do I need to preheat the oven when cooking in the iven When using as a grill the grill smokes all the time
hi, what you need to do is turn the grill on and leave it on what is happening is all the steam and fat and grease form the cooking you have done in the oven has risen and stuck on the heating element the grill uses, so open your windows and turn the grill onto its highest setting and just leave it after a while the smoke will stop.
You need to do this so that any food you cook using the grill doesnt smell of the smoke thats burning on the grill element.
Dont worry you wont do any harm to it this is a very common problem with combo ovens and grills and the same goes for microwaves with the grill feature so dont worry to much its what happens over time if you dont use the grill much.
So just switch the grill on and leave it it can take upto 20 to 30min to stop smoking but after its burned off all the grease and fat etc it will stop smoking and stop smelling so dont worry everybody who has one goes through this same problem.
let me know how you get on or if you need further assistance ok.
Its best you do this once a week or so to ensure that it dont build up to much as it can really stink the whole place out and if you cook food without burning it all off your food will taste like the smell witch believe me isnt nice, so just leave it all to burn off leave your windows and doors open and after about 20 min you should find the smoke will stop and the smell will go away.
You may find it only takes 5 to 10 min but dont worry no matter how long it takes your not doing any harm your just cleaning the element.
Dont try cleaning it with cleaning products as this can cause harm to the element and could taint any food with the cleaning product you use.
The only real help you can give is that before you turn it on to burn off the grease use a stiff hand brush and brush the element to remove all the dried on loose bits this will then make it quicker to stop smoking.
But other than that just leave it and it will sort itself out.
Jan 13, 2010 | Creda Europa E010E Electric Single Oven
Smoke coming from electric oven element
if it is the upper element is smoking when in use then its usuall grease/fatty deposits that have attached itself from previous cooks.. the only way to rid is to open doors & windows then turn to max temp to burn off... 5-10 mins usually suffice dependant on quantity. looks bad initially but soon it will be heating clean again..
Dec 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Tecnik tkc8525/2 SMOKES OUT EVERYTIME IT IS TURNED ON.
It sounds to me that you have a build up of fat and grease,, and that is what the smoke is, the fat burning off the element(s).. If the oven is working o/k otherwise, then just let it burn all the fat and grease off.
Plz rate this solution.
thanks.
Dec 17, 2008 | Tecnik TKC8525 Double Oven
Oven smokes
If it smoke smells of burnt food or grease you have something on the surface of the element which is burning off.
If it is an acrid smoke it could be the element itself is on the way out or the fan (if it is a fan oven).
You need to make a visual check of the element/fan to ascertain their condition and clean or replace as necessary.
Nov 30, 2008 | Ovens
I have alot of smoke when i use the self cleaning feature
Self cleaning works by 'burning' all of the material it is cleaning.  If you have excessive grease other material in the oven, it will cause the smoking.  Either do the cycle more frequently or remove as much of the goo as possible with a cloth before beginning.  If you have a ventilator to the outside, turn it on and close the door to the kitchen to contain the odor.
Nov 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven smoking
smoke is caused only by fat getting onto an element and should stop after a while, ie when all the fat is burnt off. this is usually a problem with the grill element.
you can get a finjhe mesh grid which fits over the centre vent in the back plate and this should help
Oct 14, 2008 | Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
888 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
