Question about Cell Phones
IPhone screen gone greenish tinged? Everything still works, including touchscreen, just has this weird green glow and sometimes vertical stripes?? Please help!
    New Friend:
Have you dropped the Iphone or has it been exposed to water damage?
It looks like a actually LCD damage and not a software failure I would recommend you contact Apple.
Here you can find the number to call http://support.apple.com/kb/HE57
Posted on Jan 07, 2013
  • 259 Answers
SOURCE: samsung monitor has white background with vertical color lines
if you have got access to another monitor try that it may be the computer or try another computer on the monitor hope this helps regards Jim
Posted on Apr 20, 2009
  • 16 Answers
SOURCE: Hi amit here, The Problem is
no it was just a software error or change some setting in camera .first you go to camera image settings white balance set it into auto and make sure that any effects is turned on when it is on select off. you can't fix your problem in this method please reset your phone go to setting /general/reset/reset all .Before you reset copy all contacts to the memory card and copy all wanted data to the card then remove memory card from the phone before resetting.it protect your data.another method is simple just remove your battery in the phone when the phone is turned on and keep some minute.after that turn on your phone it will be OK
Posted on Feb 03, 2011
CellUnlock
  • 70 Answers
SOURCE: Dropped iphone with WHITE Screen
Hi
There might be a Flex cable that disconnected in the phone, you will need to bring it to a cell phone shop or apple to have a look at it.
David
CellUnlock.net
Posted on Feb 25, 2009
GrinningFool
  • 625 Answers
SOURCE: Dropped se W810i and screen is white with vertical stripes
If you are seeing a white screen with stripes the LCD itself has gonebad. Dropping it just right some times causes the to happen without actually cracking the lcd screen
Replacing the LCD screen on the Sony W810i is a pretty straight forward procedure and should then take care of the problem. A new LCD screenruns about 30 dollars from Ebay.
Take a look at the following link to see instructions and links to buy the lcd screen
Sony W810 LCD Screen Replacement
I hope that helps out
Posted on Aug 21, 2009
SOURCE: My touchscreen started acting weird yesterday.
i had the same problem , & when i recalibrate it .. it makes it worst !!
Posted on May 25, 2010
Green snow
A greenish tone to entire display denotes a faulty panel. If you wish to get more details to this, check the site linked here. It has screen-shots to faulty plasma display. You can see it and compare to that of your TVs' and can make sure. Pull up older posts. Good Luck.
Nov 27, 2013 | Panasonic TH-46PZ800U Plasma TV
I can't get the color set.Everything has a greenish ting,The red adj. don't seem to work.Can't get natural skin tones.Can't get things red thst should be. Can I do somthig and how...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | Samsung HCM4215W 42" Rear Projection...
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Hi
David
CellUnlock.net
Feb 25, 2009 | Apple iPhone 3G Black Smartphone
Greenish screen
sometimes speaker magnets or any metallic device can cause this disturbance in this type of monitor. also, if you are using dvi, i would reset all video driver settings to default. this may correct this green tint you are seeing as well. reinstalling the monitor software could have a positive affect.
Feb 05, 2009 | Dell E196FP 19" LCD Monitor
Sony wega kdf-55wf655 very light- greenish light band on screen
probably defective optical engine. is it on all inputs and there after the tv is intially turned off ( while the screen still has glow)
Feb 17, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Greenish picture, or lack of red.
Not tuner........Did you check RGB screen adjust up front
behind access panel?.....Possible CRT issue.............T.
Nov 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Cell Phones Logo
77 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
