Question about Lexmark X4650 InkJet Printer
Lexmark x4690 won't accept new cartridges - Lexmark X4650 InkJet Printer
Ajkill
  • 2035 Answers
SOURCE: Cartridge problems with the P915 Lexmark printer.
First check they compact able once, refilled cart are recognizied
by printer,,,,
Cleaning the contacts on the cartridge carrier
Step Action
1 Power the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Gently move the cartridge carrier into a position where cartridges can be removed.
4 Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
5 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
6 Repeat Step 5 for the other cartridge slot (if applicable).
7 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
8 Plug the printer/All-In-One back into the power outlet and power it back on.
If your cartridges are not being detected when they are snapped in, do the following:
Open the cover of the printer and unsnap both cartridges.
Snap them back in after a few seconds. Close the cover.
Repeat these steps (1-2) three or more times in succession. You will be prompted to go through the menu on the printer display to finish the process. Follow the instructions displayed.
If your printer is posting a LOW INK LEVEL or CHANGE CARTRIDGE error, snap the cartridges in and out as directed above (steps 1-3). When you close the front cover, you should see the message Cartridge Change - NEW on the display.
Press Select to indicate that you have just installed a new cartridge.
Posted on Mar 16, 2008
  • 54 Answers
SOURCE: don't know how to install ink
Installing print cartridges
1 Open the printer, and then press down on the cartridge carrier levers.
2 Remove the used print cartridge or cartridges.
3 If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid.
Warning—Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridge.
4 If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid.
5 Close the printer, making sure to keep your hands out from underneath the scanner unit.
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
4 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
Posted on Apr 14, 2009
  • 1768 Answers
SOURCE: Lexmark printer x4690 says incorrect ink cartridge
1.check the instruction set here at the Lexmark site:
http://support.lexmark.com/index?page=content&id=HO3394&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X4690&searchid=1271735414583
Posted on Apr 20, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: installed new 28 and 29
    It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
    Posted on Jun 29, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: lexmark x4650 refilled ink cartridge
      Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
      Posted on Jul 05, 2011
      Lexmark X4590 alignment problem
      Alignment problems happens if the cartridge is defective. Try to replace the cartridge and make sure that it's a genuine Lexmark cartridge.
      You can also try to reseat the cartridge and clean the contacts.
      Aug 15, 2012 | Lexmark X4690 Wireless InkJet Printer
      Lexmark X5690 Use no. 4/5, after refilling, printer will not accept cartridges and won't print.
      Try to reseat the cartridges into the printer.
      Note that Lexmark does not recommend the use of 3rd party/refilled/remanufactured cartridges. These type of cartridges tend to degrade print quality and cartridge performance.
      Jul 06, 2011 | Lexmark X2690 All-In-One InkJet Printer
      This has been addressed a lot but my problem isn't solved. I have a brand new Black 32 toner for a Lexmark x7170 all in one printer. It won't accept the toner - gives me the message "left...
      It could be a faulty cartridge. Have you already tried inserting a different known working cartridge? If error continues to pop-up even with a different new or a known working cartridge, then it could be a hardware problem. Try to contact Lexmark technical support on the phone for additional assistance.
      May 10, 2011 | Lexmark X7170 All-In-One InkJet Printer
      Apr 20, 2010 | Lexmark X4690 Wireless InkJet Printer
      Are the ink cartridges interchangable between the lexmark 4650 and the 4690? They certainly appear identical in every aspect.
      Hello. The only common cartridge the X4650 and the X4690 uses is the #31 photo color print cartridge. Other cartridges for the printers are non-interchangeable. For your reference, you can click on this links to the Lexmark website. http://bit.ly/asi8dB and http://bit.ly/bvNeOa . First link shows you compatible cartridges for Lexmark X4650 and the second link is for Lexmark X4690. Hope this helps.
      Mar 14, 2010 | Lexmark X4690 Wireless InkJet Printer
      Lexmark Cartridge Error
      Are you using a Lexmark factory new cartridge? If not then please try a Lexmark factory new cartridge.
      Lexmark does not support the use of third party cartridges or refilled cartridges. Lexmark considers this to be product tampering and will void the printer's warranty if damage occurs because of the OEM cartridge.
      Please don't shoot the messenger for giving you bad news. It is the truth!
      Don
      Apr 14, 2009 | Lexmark X4650 InkJet Printer
      I have a Lexmark X4690 printer need the driver for Vista. I checked the Lexmark.com site and printer wasn't listed. Please help me with this problem.
      Go to www.lexmark.com and click on DRIVERS AND DOWNLOADS. Then use the DRIVER FINDER. In SEARCH BY MODEL, type in x4690 and you can choose a driver from there.
      Steve
      Sep 13, 2008 | Lexmark Office Equipment & Supplies
      Lexmark X4650 InkJet Printer Logo
      27 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
