Question about HP Compaq Presario V2000 Notebook
Compaq presario does not turn on
Battery light and drive light are blinking, however there is no power, power light is off. when batery is removed, all 3 lights are off. is the problem with the ac adapter?? pls advise what can be done to rootcause & fix the issue? thanks!
  • sheetal kap Jun 30, 2007
    thanks!
    the ac adapter # is 402018-001
    i have had it just for an year, surprised how the ac adapter could go bad.
  • Rettat Nov 08, 2007
    I had someone test the adapter and it did not show any signs of life so I went online and ordered one. If this is not the problem how can I go inside and make sure the connector is secure?
  • 432 Answers
Your battery is dead. You need to get a new power adapter. The battery isn't charging. The AC adapter went south. If the laptop is under warranty, you can get one from Compaq. Or, what I would do is shop on the internet and order one. Whats the numbers on the ac adapter? I'll help you find one.
Posted on Jun 30, 2007
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Compaq presario C301TU laptop no power
Remove the main battery and try to power up, if it works replace the battery, no change! remove one stick of ram memory and repeat keeping one stick at all times, if none of these work the problem is more than likely the motherboard.
Jul 28, 2012 | Compaq Presario 700 470024-192 Notebook
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Compaq Compaq Presario CQ62 white screen
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 01, 2012 | Compaq Presario CQ62-112TU
Compaq presario f577cl wont turn on
Turn it on, then hold the power button for 4 seconds until it forces off. Turn on again.
Otherwise, turn on, remove battery, insert battery, turn on.
Please rate.
Aug 21, 2009 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Will not turn on
Probably needs a new battery, simple to remove, there should be a little slider on the bottom of the laptop that u flick accross and the batery will come straight out :D
Dec 06, 2008 | Compaq Presario Notebook
Doesnt power on or charge
Sounds like your hard-Drive is not reponding.
Jul 27, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario laptop blinking power button
REMOVED BATTERY AND CHECK ONLY IN AC MODE
IF ITS START PRESS F8 AFTER BOOTING AND OPEN IN SAFE MODE
Jun 21, 2008 | Compaq Presario Notebook
Screen not coming on
It is a display problem.Better to take any nearest service center.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Batery light blinking
try rundown the battery 3 times if still not holding charge your battery is faulty you have to replace it.
regards
Richard
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
200 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
