Question about HP 49g+ Calculator
My problem is not fixed
I changed the batteries, HP49+g all of them, and the indicator low battery keep on.  I sent you this problem some days ago and your answer did not solve my problem
  • odelgado Jan 21, 2009
    Resetting the HP49g+ I would lost all the programs I have made.
    The problem I have is every time I change de batteries, and I believe to reset the calculator every time is not practical.
    I sent the problem again
    I still have the problem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Use duracell AAA batteries for better use.
if your problem not gone.
this is your 49+g hardware problem it congept more it can.take it to service center.
Posted on Jan 25, 2009
    Brigadier General:
  • HP Master
  • 3,614 Answers
Stretching springs in the battery compartment to fix battery contact problems,
cleaning the battery terminals.
..and if all the checking and correcting this still have the problem, could be a fault on the large electrolytic capacitor to the main board.
hope this initial info helps.
Posted on Jan 21, 2009
  • 10,594 Answers
Please check any corrosion on battery terminals of calculator. Battery terminals should be clean and shiny.
  • 15,935 Answers
Please re-post the problem in full so we can better help you
    Genius:
  • 1,913 Answers
Reset all settigns to factory defaults.also clean dust from circuit u can do it.come on.
  • kishor khatri
    kishor khatri Jan 21, 2009
    check your new batteries purchase proper voltage batteries and branded
2006 grand caravan i need help finding the receiver on my Van the gets the signal sent from my remote key It's not working on the right side only until I get very close It's always worked very well from...
This indicates that the battery in your key may be of low voltage and the transmission range is less than optimal.. have the battery replaced and see if that fixes the problem. Keep the time taken to change the battery to an absolute minimum or you may have to have it reprogrammed to the car.
Apr 26, 2014 | Cars & Trucks
I have a 3054. About 3 days ago it reset to 1-1-2005 and has never changed. it now reads 1-3-2005 at 5:57 PM
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
Jul 25, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
If a bulb is out will it make 15A on #2 keeps on blowing out. Changed the relay, hi/lo beam switch. Low beams still won't work. Can't keep a fuse in it cause it blows out. This is for a 2000 Sonata 4 cyl....
the only thing that causes a fuse to blow is a short. I would say a wire is pinched somewhere, the question is how to isolate and fix. I guess have a handful of fuses, since you say it is the low beams I would disconnect one light and see if it blows the fuse. I am thinking that the most excellent place to start is where the battery is installed. As a wire may have been nicked or crimped, for the low beam on the passengers side. Hope this helped
Sep 23, 2010 | 2006 Hyundai Sonata
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
Outbox keeps sending
TRY REMOVING THE BATTERY AND IF IT HAS A CHIP THAT 2. LEAVE IT LIKE TAT FOR LIKE A DAY WITHOUT TURNING IT ON AT ALL.
Jun 18, 2009 | LG KC910 Renoir Cell Phone
Low battery message, sent back to canon to repair and still having same problem..can i send back yet again. where to? or can i get a new one.
I had this same problem. I tried this procedure and it seems to have worked so far:
1. run a set of batteries down in the camera so the voltage is so low the camera won't even power up fully.
2. put some cheap (non-alkaline) batteries in and run these down.
3. get some hi-power alkaline batteries (the kind that are marketed as 'photo' batteries or similar, they do cost more) and put these in. Hopefully the 'low battery' indicator has now been reset.
This worked for me.
Nov 15, 2007 | Canon PowerShot A520 Digital Camera
Casio GW-1200BA G-Shock
Try taping it to the inside of your window for a couple days and see if that makes it charge up enough to act right. You might also want to make sure that you don't have the "auto light" on. If the light turns on when you tilt the watch to a 45 degree angle then press the light button for 2 seconds to shut that off. If that doesn't work for you then you are probably going to have to have the battery changed.
Dec 31, 2006 | Casio G-Shock GW1200BA-1AV Wrist Watch
HP 49g+ Calculator Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
