I have a pearl a/c and the display screan shows E4
My portable goldstar airconditioner is showing E4 .What does this mean
E4 is a Display panel communication error.
Might have been something as simple as a Power Surge.
Power unit off for 30 minutes and then restart.
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Goldstar Heating & Cooling
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Carrier casement unit shuts off automatically
E4 indicates your unit is in need of service.
May 07, 2008 | Carrier XHC101D Air Conditioner
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
