Question about Mitsubishi LT-40134 40 in. HD-Ready LCD Television
Colored vertical lines on the right side of my Mitsubishi 40" tv
herman2008
  • 7 Answers
SOURCE: Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Posted on Jan 16, 2009
  • 12 Answers
SOURCE: colored vertical lines on half the screen
yeah get a new tv, and not a mitsubishi, they all seem to have the same prob over time. the lines mean that your picture is on its way out
Posted on Apr 25, 2009
  • 53 Answers
SOURCE: vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Bad/Going Bad/Will go horribly bad TCON board (small circuit board sitting at the top of the panel in the back).
Most likely, the whole panel will need to be replaced in order to rectify the issue.
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Posted on Oct 26, 2009
Sony tv KDL-40S4100 vertical lines on right side
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Mitsubishi LCD #LT40148--left side of screen has vertical lines.
I would guess a sustain or similar board---one for each side of the set and typical shop repair will exceed 200 parts and labor
Mar 17, 2012 | Mitsubishi LT-40148 40 in. LCD TV
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Colored vertical lines on half the screen
Apr 25, 2009 | Mitsubishi LT-40134 40 in. HD-Ready LCD...
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi LT-40134 40 in. HD-Ready LCD Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
