Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050P washer just tarted leaking at the front bottom
Below the lint cover, which i have cleaned out
it was a refurbished model and dont think a warrenty is invovled
any suggestoins?
I bought mine used and it started gushing water from the same location, and after i took it apart, there was large plastic pvc drain pipe that had cracked. we took it out and put epoxy on it and it doesnt leak.
Posted on Feb 25, 2009
  • 121 Answers
Check rubber on door
Posted on Feb 16, 2009
It is a whirpoool wahser model GHW9100LW2 and it is not draing correcty, i have clean the drain hose, and read where there is some lint catching device inside the washing machine, and i read if i can get...
That screen/filter for the drain pump is located under the lower panel below the main front panel where the door and whatnot is. Remove that panel by removing the screws from the bottom of it. On the right side at the bottom will be this big white thing,unscrew it just a little bit and have some towels ready to catch the water that will come out of it,once the water stops coming from it,unscrew it completly and pull it out and will see all sotra stuff in it blocking the water flow into the pump.Obvously once ya clean it screw it back on and reinstall that lower panel.
UNPLUG THE WASHER TILL BACK TOGETHER COMPLETLY
Good luck.
Gene
Aug 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050P Washer- Can I use Clorox bleach for my whites? Where do I put it?
It is not recomended to use bleach in these machines...that's why there is no place to put it in the dispenser...
Nov 14, 2010 | Whirlpool LHW0050PQ Front Load Washer
Washing machine is not completing spin cycle at high speeds. Only goes slow speed tumble for a few times and then stops.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Jun 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Inop.
Pl rate me nice for the free help, thnks
Jun 04, 2010 | Frigidaire GLTF2940ES Front Load Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
The clothes in my duet washer come out soaking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Pl rate me ‘very helpful’ for the free help!
Jan 24, 2010 | Whirlpool AWM9000 Front Load Washer
E20 message I get on my washer machine
Apr 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Getting an error code E20.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 12, 2009 | Frigidaire ATF6000ES Front Load Washer
My towels always smell sour...it doesn't matter what detergent or fabric softener I use. I have the Whirlpool Duet front loading machine and dryer.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Jan 20, 2009 | Whirlpool Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal De
