The main speaker fell and the volume control knob is loosened. I opened to take a look but the volume knob fell off completely. Is there any way to raise the volume from inside without using the volume knob? Power button works just fine
SOURCE: Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
SOURCE: Using Without WIRED REMOTE
All I could suggest is run the decoder off the line-out of your soundcard, then regardless of what the volume or power setting is to your speakers, the signal will still come through?
Tony
SOURCE: No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
SOURCE: One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
