Question about Coby Usa Coby Electronics TFTV992 9 Inch Atsc Digital Portable Tv
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
Good afternoon. My name is Carlos and I'm writing from Brazil. I just received a Coby TFTV992 9" portable TV bought at B&H PhotoVideo. I'm trying to tune the TV channels without success. I made the tuning procedure many times and it didn't work neither through "air" (with the built in antenna or the external antenna) nor through "cable" (with a cable that is working fine with another LCD TV). After all the tuning procedures, the Coby TFTV992 shows the on display message: PLEASE RUN CHANNEL AUTO SCAN. Am I doing something wrong? Thanks. Carlos Kulps carlos.kulps@globo.com
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Posted on Mar 16, 2013
  • Sol de Noche Luna de Dia
    no tendran el diagrama de la tv naxa nx-572, o que me digan que condensador es el C114, que numero y que material
Brazil and USA have different digital systems. Your american Coby tv will not work in Brazil
Posted on Jul 26, 2013
  • Andy Moliere Charles X
    Andy Moliere Charles X Oct 26, 2013
    I have the same problem with Carlos but i'm in Haiti, I do everything and without success.
I can't receive HD channels
Roy, change your cable, must be faulty and not giving a signal to TV.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 02, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
Trying to tune tv to channel 3,but it doesnt want to stop on 3. goes all around the dial will stop on 2or4 but not on3.
Did you try to manual tune/search the channel? If you are using the autosearch/tune feature and the signal is not strong it will simply skip the channel. Find channel 3 with manual search and then save it. Good luck!
Dec 14, 2007 | Televison & Video
How do I connect an external DVD/VHS player to an old Coby Cx-Tv1 television with no RCA cable?
It should have also an Audio in jack . Take a photo of it and go to some radio/tv parts shop for a converter. They know
May 17, 2015 | Coby CX-TV1 5 in. Portable Television
I can get signal
where did you buy the tv, might not the same broadcast signal in your location. by the way have you been tried to have manual fine tune of any local channel or auto search so you can get available channel in the area.
Nov 17, 2012 | Coby TFTV1212 12 in. LCD TV
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
I am purchasing a Coby KTFDVD1093 under the counter (10") television; however, I am concerned as the reviews I am reading online indicate that the user has only one opportunity to auto tune in the...
that is not going to be a problem. To those it happened to, the TV has a fault that is why. It is not that it happens to all Coby KTFDVD1093.
Electronics in general does not have 100% assurance.
There is nothing to worry about, you can go ahead and purchase your Coby KTFDVD1093.
I hope the above is clear. If not, please let me know.
Regards.
Jun 16, 2011 | Coby KTF-DVD1093 10 in. Under Cabinet TV
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
Coby tf-tv700 a 7in lcd tv will not git channals since diggital s
Go to menu pick rescan channels,not getting more channels,get digital antena.Rescan again.
Aug 15, 2009 | Coby TF-TV700 7 in. Portable Television
Coby Usa Coby Electronics TFTV992 9 Inch Atsc Digital Portable Tv Logo
466 people viewed this question
Top Coby Usa Televison & Video Experts
Electro Med Services...
Are you a Coby Usa Televison and Video Expert? Answer questions, earn points and help others
