Epson Stylus C43SX InkJet Printer Logo
john tenerife Posted on Jun 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A communication error has occurred. i can't connect to the printer>>> epson stylus c43sx
  • 3 more comments
  • Anonymous Feb 08, 2008
    i have the same communication error with my c43sx, but then i,ve tried reinstalling the driver several times and during installation the computer was able to detect the printer. But sometime during the installation process when the software checks the connection it reported again the communication error or the software would install but when i tried to print it would again lost communication with the cpu.. I've tried connecting the printer to another computer and it worked and show no sign of error, but when I connected it back to the original computer, it shows communication error again, i've tried using a known good cable but to no avail. I've tried setting the port to correct set-up (ecp, then epp) but to avail. I also have temporarily disabled the antivirus during set-up, then turned off the firewall but still i get the error message.Then I restored the system to the time when the printer is fully functional (just to see if it is a software problem).I was thinking there could be a problem with the motherboard's parallel port (just a hunch).
  • Anonymous Apr 01, 2008
    the printer does not print. ngpaper jam xa nung-una tapos pgtanggal ko ng paper ay naging gnito na xa..pgmgtry ako mgprint ay walang ginagawa ang printer.tulogn
  • Anonymous Mar 12, 2014
    I keep getting a "Failed to communicate with the EPSON Connect Server. -2" error. I've rebooted, turned the printer on and off and it still won't print.
  • Anonymous Mar 17, 2014
    epson stylus sx600fw
  • Anonymous Mar 19, 2014
    Epson printer stylus NX430 cannot acquire connection toWiFi router
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
536
Points
Thanks jackboy for the info. i believe it really was the parallel port having trouble. I tried to print in DOS prompt using the command c:\>dir>lpt1 and it didn't print.
A
Anonymous
I've never been encountred such a unreliable printer in my life... this kind of printer has always trouble, problem.. i decided to change my printer to other products... i'm sorry but these are all true... i recomened you not to buy this printer it will just bring you a big headache...
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jun 30, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027867
Points
5636
A.Unplug and re connect the printer B.Go to Printers and Faxes and click on install printer. When sked for CD or go to list- select - Go to List Select Make Select Model Click OK Make it your default printer
How to connect epson c43sx printer to a compaq laptop?
get a printer USB cable you can buy from Staples or Bestbuy about 30 dollars. Then install the software/driver to your laptop then connect the USB cable to the laptop
Download epson stylus C43SX to my computer for installation
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
6helpful
How to download epson stylus c43sx driver?
You can download the printer driver for your model printer from Epson download & support. Please click on this link and select the Windows version of the driver your require :-
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
2helpful
How to install an epson stylus c43sx without a CD
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=1&pid=2
go to this site and ch the downloads
Printer cartridge
See the self-help and Reference Manual here:
http://tech.epson.com.au/downloads/message.asp
The self-help in particular is clear and easy to use.
1helpful
Epson c43sx not printing
Make sure tiy have set the utility tocyour model of printer,
Make sure all connections are correct.
Reload the software.
Does the printer give a message of some sort?
2helpful
4answers
C43sx both lights on
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
