Question about HP LaserJet Pro 400 color Printer M475dn
Hp lj 482 error
Error 482
Hp laserjet p3005n 55.04.92 dc controller error
I need help,my printer are hp lj 3035,the error is 55.04.92-DC CONTROLLER ERROR,how to fix this erroer?
Feb 21, 2012 | HP Hewlett Packard LaserJet P3005n Printer
Tec B 452 error 482 run time error, printer error
This is a problem with windows error 482 is probably a problem with activeX
Jan 04, 2012 | Toshiba TEC B-452 Thermal Label Printer
Hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Jun 17, 2009 | Office Equipment & Supplies
Tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Feb 06, 2009 | TimeValue Software TValue 4.0 for PC
Can not get a hp lj 1022 installed
Go to www.hp.com and let the website auto-detect your printer and down load the drivers automatically
Jan 16, 2009 | HP LaserJet 1022 Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
HP LJ II P plus
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
Jul 25, 2008 | HP LaserJet IIp plus Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP LJ 3020
The scanning unit is faulty, u may trying cleaning the scan unit ,else it needs replacement.
Happy printing
Omnipresent
Oct 17, 2007 | HP LJ 3020 All-In-One Printer / Scanner /...
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet Pro 400 color Printer M475dn Logo
22 people viewed this question
Seeker5211
Seeker5211
