Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
Mother board does not boot - Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 08, 2013
My computer will not boot up,mother board problem?
could be a mother board problem but before you replace it try a few things first
remove the memory and try to boot
unplug all hard drives apart from master and try to boot
go into the bios and load default settings rty to boot
when you mean doesnt boot do you get the welcome screen ? says windows xp etc
if so then its a windows issue and you need to reinstall windows
if after trying all of this the yes maybe its a mother board issue
hope this helps
John
Jul 07, 2011 | Intel Computers & Internet
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
My Mother Board Intel. My Hard disk is not
May be ur system doesnot support the harddisk. Go to BIOS settings in the Advanced option see if the hard disk is detected or not, if not then check the connections of the hard disk and then go to boot priority and change first boot device to cdrom and then try
May 06, 2010 | Intel Motherboard
The system getting restart continiously
just try to boot without hardisk if a boot screen appears showing that the motherboard have no problem . and then buy a new ram and insert it . buy a correct ram
Apr 26, 2010 | ASUS P5GC-MX/1333 Motherboard
Hp 873n desktop opened case to clean, was very dirty (alot of dust bunnys) unpluged and took outside to blow it out with canned air cleaned all fans and entire case pluged in all and fired it off and got 1...
Wow...did you use a vacume anyware near the mother board? the static on the end of a vacume hose is REALLY BAD NEWS TO A MOTHER BOARD.
Try to reseat all cables and plug's. try to boot again.
If that doesn't work try this.
Remove all PCI DEVICES. Try to boot with just the power cable... bare bone mother board....will it post?
If not remove the board from the case...try booting again...if she doesn't boot ast this point , the board took a static hit...she's toast...sry..:)
Please leave feed back
Thanks
Feb 23, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
R4EQUEST FOR SOLUTION FOR 865 INTEL CHIPSET
if u boot by own harddisk u desable the booting devises else than hdd and cd rom by using (in POST screen ) DEL or F2 ,and select boot devices -desable the lan boot OR select the only one boot device that is HDD ,then save and exit using F10 or refer onboard instructons
make sure TRY TO OTHER BOOT DEVICES is enabled (if u got BOOT FAIURE massage at first start up)
all the best ,keep trying,
regards
prasanna
Mar 05, 2008 | Intel PENTIUM-4 FSB800 Mother Board with...
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Mar 02, 2008 | Intel Motherboard
Processor for P5VDC-MX
Hey there alcouto, your motherboard supports Intel Celeron, Intel Pentium 4, and Intel Pentium D processors. The socket set is LGA775. The FSB should be no higher than 800Mhz. It appears you have purchased the wrong CPU for your board. I hope the rest of the info helps you on your next purchase. Good Luck!
Jan 29, 2008 | ASUS P5VDC-MX Motherboard
Cannot boot in Slave mode
i have never heared of any hardrive being able to boot when it is set as slave, as the master is always the 'C' drive from which windows looks for the master boot record. why, if you have only one hard drive is it set as slave?, it doesnt make sense. No hard drive will boot up if there is no jumper cap on it, as the motherboard needs to know which hd is master and has the o.s on it.
Jul 28, 2007 | Asrock P4I45GV R5 Motherboard
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
42 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
