Question about GE DBL333EA Electric Dryer
GE dryer has trouble starting.
GE DBL333EA Electric Dryer: The dryer will start once after a long period of rest, but have to hold down the start switch like priming. If it doesn't start it will grind till there is no sound on the start, then dead untill another long period of rest. The dryer does not run each time the start switch is turned. If the dryer runs, everything works just fine.
  • jhobbs4 Feb 09, 2009
    Sounds like the overload switch is cutting out , my gues will be that the motor is going bad. Just replaced mine was doing the same thing.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryerGE dryer has trouble starting. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The GE dryer has trouble starting. - 2_bing.gifsrc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 29, 2010
Belt installation
HI, Looking at the idler assembly from the back, move the idler wheel to the left (spring loaded).
Slip the belt on the motor pulley with ribs touching pulley. Now let the idler pulley rest againdt the back side of the belt.
I hope this helps you.
Please let me know if I can help further.
Vic
May 23, 2009 | GE DBL333EA Electric Dryer
Dryer doesnt start up at all
You must clean the dryer. Remove all lint from it and the vent and look for the FUSE here.
May 12, 2009 | GE DBL333EA Electric Dryer
Dryer switch grinds and sometimes starts, most times not
Jan 20, 2009 | GE DBL333EA Electric Dryer
GE dryer DDE5300 runs only if you hold start lever- burnin smell from motor, Is there a start switch on motor?
Broken belt. The safety switch will not allow the motor to stay running if the belt is broken. Open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On some these dryers there is a friendly rear hatch to help you replace the idler.
Jan 09, 2009 | GE DBL333EA Electric Dryer
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
Ohms
volt ohm meter get one at walmart 15.00
Aug 25, 2008 | GE DBL333EA Electric Dryer
Creda tumble dryer
It is probably the electric heater coil. How old is the machine? If a couple of years or more, the coil is probably burnt out. It is accessible through the back. Good luck!
Feb 08, 2008 | GE DBL333EA Electric Dryer
GE DBL333EA Electric Dryer Logo
281 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
