Question about Kenmore Sears Dryer Heating element PS334313, AP3094254
Kenmore dryer Model #96375100 heating element not heating
jsrock516
  • 5911 Answers
SOURCE: Kenmore Dryer Model 110
There are several things that can cause a dryer not to heat properly.  First and foremost, a dryer needs proper air flow in order to work properly.  Routine cleaning of the dryer vent hose should be done periodically.  I recommend once per season (4 times per year), depending on use.  If you haven't cleaned the dryer vent any time recently, start here first.  It could be that you have a simple clog somewhere.
Now...if you've already thought of that, you could actually have more going on INSIDE the dryer.  If your dryer is equipped with a removable front kick panel, remove it by inserting a putty knife along the top seam (about 2 inches in front each side) to release the retaining clips.  The panel should pull open, exposing the heating element and blower housing.  On some models the heat components can be accessed by removing the back of the dryer.
Stand back and watch the heating element with the dryer running.  If it is glowing and intermittently shutting off, this is NORMAL.  You probably have a clog some where INSIDE the dryer.  You will need to unplug the dryer and remove the air blower housing to see if it is clogged with lint.  I have found these blowers so clogged that the fan gets jammed with lint and snaps off at the shaft.  If the fan doesn't spin, there is no air flow and you clothes will not dry.  In this case, the blower fan will have to be replaced.
If the heating element is NOT glowing, and you have verified that the dryer is not clogged, you may have a failure with any of the following components:
HEATING ELEMENT - located inside a heat box.  Unplug dryer and remove connector leads from element.  Check resistance of the heating element.  It should be about 10 ohms.  If it is OPEN, the heating element is bad.
THERMAL CUT-OUT - located on the heater box housing.  Has two leads running to it.  Designed to protect the heating element in an overheat condition.  Check resistance to ensure it is reading something close to a SHORT (0 ohms).  If it is OPEN, it must be replaced.  It is highly recommended to replace the HI-LIMIT THERMOSTAT (which is also located on the heater box, closer to the heating element connectors).  The two components work in conjunction to regulate the heating element temperature.  If the TCO fails it is usually for a reason.  It could be a simple matter of general house cleaning, or it could be a failure of the hi limit thermostat.
I hope you find this information helpful.  Let me know what you find.  Post back with any comments and/or questions.
Posted on Oct 13, 2007
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer does not heat.
DEAD DRYER
Posted on Feb 07, 2009
jsrock516
  • 5911 Answers
SOURCE: How do you replace the heating element on kenmore
Have you confirmed the heating element is bad? There's more to the dryer heating circuits that can cause a no heat problem besides the heating element.
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
Now...if you have determined the heating element is definitely bad, and this is a Kenmore Elite as the one you posted this question under, the following link explains how to access the heating element and replace it: http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Posted on Jan 06, 2010
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
Kenmore dryer model 64781 no heat
if it is a top mount lint filter you can remove the back to get to it,if lint trap is inside the dryer you get to it in the front-do you have a meter?mike
May 21, 2009 | Kenmore Dryers
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore Sears Dryer Heating element PS334313, AP3094254 Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
