Question about Sewing Machines
Why is my kemore 1785 making a knocking sound?
Machine makes a knocking sound as I increase the sewing speed.
  • Sewing Machines Master
  • 7,365 Answers
Could be a loose or broken part or the machine may need some type
of adjustment,,it would be a good idea to have the machine serviced.
Posted on Jan 08, 2013
  • 106 Answers
SOURCE: Pfaff 2029 sewing machine.
No the sounds are not normal,
I would suggest you have the machine looked at by a sewing machine tech.
I have never come across this problem before and would need to look at the machine before making a diagnosis.
Sorry to be of little help but it would be unfair to give bad advice.
Posted on Apr 02, 2008
RickE1
  • 202 Answers
SOURCE: Knocking noise when sewing
If the machine does not knock when in straight stitch then it is the stitch width limiter. You would have to take off the side cover with a T20 torx screwdriver. Once open you will see an elongated U-shaped piece with a screw through the bottom of it (its maybe a half inch long or so). Its just above that big bottom thread guide. I think you need a T10 torx driver, loosen that screw and move that u-shaped part slightly (very slightly) so it isn't hitting anymore on the side to side action. It happens but can't really harm anything.
I'm sure thats it.
Posted on Dec 20, 2008
SOURCE: Kenmore 385 sewing machine won't sew
try oiling the machine
Posted on Jan 06, 2009
mohammed387
  • 1952 Answers
SOURCE: sewing/embroidery machine janome mc9700 making
Please be more specific with the clicking noise that you are hearing- when does it make that noise, is the bobbin case in or out, where is it coming from,
Posted on Aug 26, 2009
  • 96 Answers
SOURCE: kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
Posted on Dec 13, 2009
Brothers Electric Sewing Machine Knocking noise
First thing, install a brand new needle. A bent/damaged needle will frequently make noises.
Second, if it is mechanical machine (not computerized), it most likely needs a good cleaning and oiling.
Will not zigzag or decorative stitches New to these newer plastic style...
If it continues to make a knocking noise, it could have a bent part or be out of time, in which case you should contact a service repair shop.
Apr 13, 2016 | Sewing Machines
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
My sewing machine started making a clunking noise
Try a brand new needle. A bent, dull, or damaged needle will cause havoc. Changing the needle frequently is necessary to keep the machine functioning well. It is a "very" inexpensive fix for a lot of sewing machine problems.
Mar 06, 2016 | Sewing Machines
Memory 3000 makes occasional screeching noise
Take in in for a Maintenance. There are many areas the may need a drop of oil, or adjustment. You don't want to do it.
Mar 25, 2015 | Janome Memory Craft 3000
Knocking sound on brother 1034d brother serger
Stop using the machine. If your loopers are out of adjustment you will break them and increase your service cost by 3 times.
Aug 31, 2014 | Brother 1034D Serger Sewing Machine
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
I have just bought a new bernina 440QE - it makes a loud noise when turned on, which gets louder when you increase the sewing speed - I have a 240 which runs much quieter - is it a fault or is it normal?
That is a great machine, should sound realy good. Should sound just like a 240. Are you lubricating the hook (that is important with the 440). If that does not help I would take it in.
Apr 05, 2011 | Bernina Sewing Machines
Error 1 message will not leave
Hi - first, check your manual to see if the error is described somewhere. Follow the instructions. If the manual tells you to take the machine in for repair, try a couple things first.
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.
After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
Dec 20, 2008 | Kenmore 19365 Computerized Sewing Machine
Pfaff hobby 1132
Many users also had such knocking sound and loops problem. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Sep 09, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
