Question about TDK Electronics - Others
Can't remove write protect from my tdk flashdrive
  • vicardo Jan 13, 2013
    i still have the same problem
  • TDK Master
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Posted on Jan 11, 2013
    i tried but it didn't wirk
  • Brian Sullivan
    Brian Sullivan Jan 13, 2013
    need more dtails on what you tried ? which operating system ? are you the computers administrator ? You can remove write protection from your drive using the below method: Open start menu, in the search bar type regedit and press enter. This will open the registry editor. Navigate to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies If the registry key Storage Device Policies does not exist, you will need to create it manually. Double click the key Write Protect in the right window and set the value to 0 in the Value Data Box and press OK button Restart your computer
2 Suggested Answers
SOURCE: locked out
http://www.tdk-media.eu/downloads/trans_it_usb_password_pr_english.exe
Posted on Jan 15, 2009
Can not format
at command prompt type chkdsk x: /f /r where x is the flashdrive /memory card
Dec 30, 2013 | TDK Electronics - Others
Write protection of flashdrive
Try this link
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
Mar 26, 2013 | SanDisk Cruzer Edge 4GB USB flash drive -...
I copied all of my data to 16gb tdk trans-it flashdrive.and when i wanted to work with my files it says insert disk in removable drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Mar 08, 2012 | TDK Electronics - Others
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
TDK Trans-IT 8gb flash drive is unable to format. It gives an error that says this disk is write protected, please assist.
get a copy of the software from TDK itself at:
it's a self contained .exe file no installation needed. This will format your flash for you if you need to and the program gets retained.
if you want a pc based format copy the software somewhere in your hard drive. in myu computer right click your flashdisk, format (fat 32 better). There clean as a whistle. copy back flashlock, then partition as you wish.
May 10, 2011 | Computers & Internet
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Jetflash v10 flashdrive is write protected
try hp drive boot utility http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&mode=3&taskId=135&swItem=MTX-UNITY-I23839
Jun 08, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect on my usb flash drive
On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
Oct 08, 2008 | Computers & Internet
Locked out
Oct 20, 2007 | TDK (CD-RW74HSFXS5) Storage Media
Electronics - Others Logo
320 people viewed this question
Top TDK Electronics - Others Experts
 Grubhead
Grubhead
Sandy Moore
Sandy Moore
Jim Goldsmith
Jim Goldsmith
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
