Question about Chamberlain Tools & Hardware - Others
Waxmaster Model900w replacement prts
Key # 17-9000 counterweight
Chamberlain waxmaster 900w parts
Waxmaster Polishmaster Buffer Pads Bonnets
based on the price there are no repair parts. Unfortunately it's disposable.
Jul 30, 2017 | Building Materials
Waxmasters
Buffing pads, you will need to use one with long knap. Look like wool.
Aug 07, 2014 | Waxmaster Tools & Hardware - Others
Broken cables and counterweights
Call Techmotion 877-805-1030. We can get you fixed up.
Oct 03, 2012 | Body Solid Counter Balanced Smith Machine
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight,...
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Oct 12, 2010 | Audio Technica AT-PL120 Turntable
Do you sell replacement pads for the 9" waxmaster w109
Replacement parts for waxmaster w109 can be found at amazon, take a look here: Amazon com waxmaster w109 parts. I hope this was helpful. Cheers
Aug 18, 2010 | Chamberlain Standard Duty Polisher/Waxer
How do you remove the foam from the waxmaster?
I inserted a screwdriver in a slot of the holder and unsrewed it, counterclockwise. I could not find a replacement so i glued it back on.
Sep 06, 2009 | Chamberlain Standard Duty Polisher/Waxer
Our praise band keyboard has a key that won't return to the "up" position.
With the "Sing-spiration" only 3 hours away, we, John Cobb (the keyboard player) and I, decided to jump in and find the problem.  We removed the covering on the backside, removed the keyboard from the base, and when we saw the bottom of the keys, found a broken counterweight.  It was from the mid-G key that wouldn't work.  John said he doesn't use the high-G key much, so we took the good counterweight off of high-G and replaced the broken weight.  After replacing enough screws to keep the keyboard assembled, John "tested" it for the nites playability.  All is great!  We'll go to the local music store today and order a new counterweight.
The Sing-spiration was a great success!
cuinsemo
Sep 21, 2008 | M-Audio US85100 Keyboard
Tools & Hardware - Others Logo
Top Chamberlain Tools & Hardware - Others Experts
John Trevino
Are you a Chamberlain Tool and Hardware - Other Expert? Answer questions, earn points and help others
