Question about Kenwood KSC-WA100 Car Subwoofer
How can i add a monitor to fact overhead tv/dvd
Im trying to add a lcd monitor to my '05 tahoe factory overhead panasonic tv/dvd, but the dvd player has no outputs on it, how can i wire it in?
  • 77 Answers
You would have to get a schematic of the wiring either from the car manufacturer or website then it would be basic splicing and connecting. down side is tearing apart your ride for the new monitor. if you need more installation help sure someone can answer ya for a premium
Posted on Feb 19, 2009
Why would my interior lights and door locks come on and go off and the driver door ajar comes on while going down the road, whats wrong?
This could be several things. Check the switch on the door frame. There is a pushbutton that sticks up and if the wire comes loose or the switch is bad, it can cause this. Also the items are controlled by a computer called the BCM. This is an expensive item to replace.
Jul 18, 2014 | Panasonic Gmc Tahoe Chevy Suburban Yukon...
I have a 02 pontiac montana with factory dvd and overhead monitor. is it possible to replace factory stereo with aftermarket dash cd/dvd player and have it play through overhead monitor and aftermarket...
yes,u can get it done for sure.u might need wiring kit to joint the system together.make sure u can get the kit before to buy aftermarket system.
Jan 27, 2014 | Cars & Trucks
How to get the dvd player to play threw my truck speakers?
if you dvd play came with a wireless fm modulator read the owner manual and set up the fm station to get it to work . if it does not have a built in fm modulator you need to buy one.
the pull out your radio and run power to the fm modulator and then connect the factory anntenna to one side of modulator and the other side goes back to your factory antenna location at radio . then set the fm station you set for the fm modulator run a set of rca cables from the fm modulator to the dvd flip screen and it should work . i would think your flip screen dvd play would have a built in fm modulator that is wireless .
caraudioquestion@gmail.com
Oct 28, 2010 | Insignia Mobile DVD Player with 9.5"...
I need installation directions for my overhead dvd player 9.5. I want to put it inot my 2003 gmc Envoy
Installation directions for an overhead DVD? If you have never done an overhead DVD installation, I recommend that you have it professionally installed.
Sep 22, 2010 | Insignia Mobile DVD Player with 9.5"...
Just bought a used toyoya and it has a drive mobile entertainment system dvd player in it. I can't get the headphones to work
Okay first of all im going to assume you are using wireless headphones.If thats the case make sure your overhead will operate wireless hphones. If you can see some hidden leds it does go to menu on your unit and make sure the infrared headphone is turned on.
Jul 30, 2010 | Drive Mobile Entertainment DME-OH101 10.4"...
Acer x203h only yields 720x480 resolution with Panasonic DVD player via HDMI output. Pana will not allow setting to output higher than 480p attached to this monitor. With computer, can adjust to full res...
The fact that other devices can go higher than the resolution provided by the panasonic dvd player is a strong indication that this is not a screen issue but one with your dvd player and you should consult the manual or web site for your particular model to find out what its limitations are
Aug 11, 2009 | Acer X203H bd Monitor
Audiovox DVD overhead Monitor
the power supply amperes might be too low try using car batt as your power source
Nov 09, 2008 | Audiovox VOH8512 Overhead LCD Monitor Car...
Ejecting a dvd
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Sep 22, 2007 | Audiovox VOD1023 Overhead LCD Monitor -...
DVD's or Unit?
There are techs out there that are so good that they can actually adjust the setting on the the laser assembly itself. I used to do it to compact disc players all the time it was just a variable resistor on the laser assembly. Dvd players general have two one for CDs and one for DVDs. What this does is it allow the lens to focus slighly better. But most techs will not adjust them anymore due to the fact that if you have to adjust this from the factory preset. that means the laser is starting to fail. and will eventually need to be replaced anyway.
Jan 06, 2007 | Bravo OHS-102 Overhead LCD Monitor - 10.2"...
Kenwood KSC-WA100 Car Subwoofer Logo
277 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
