Question about Delta 40-695 20" Variable-Speed Scroll Saw
Scroll saw #4906 table wobble .Blade will not center in table hole
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
I have a 10" ROK tile saw which shakes violently
MAKE SURE THE BLADE IS RUNNING TRUE, UNPLUG SAW ! BRING THE BLADE DOWN TO THE CUTTING DECK, WITH YOUR HAND TURN THE BLADE, AND WATCH WHAT THE BLADE DOES. THERE SHOULD BE NO SID TO SIDE OR UP AND DOWN MOVEMENT IN THE BLADE ! THERE IS LITTLE WASHER KITS THAT MAKE CENTER THE BLADE TO THE DRIVE. OR IF THE BLADE WIGGLES WHEN ALL IS CENTERED, IT MAY BE A BAD BEARING IN THE BLADE HEAD.... IF I WAS OF HELP HIT THE YES BUTTON.. THANKS JAY.. THE MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 20, 2011 | Diamond Products Mk - 101 10" Tile Saw
My blade appears to cut or move straight. But when I cut a piece of wood on it it wobbles. You can't wobble the blade with your hand. It appears to be in there tight. What could be the problem?
You likely need to replace the blade i have hitachi 10 inch chop saw with the lazer i love it the best one i have ever had vary well build But any saw is olny as good as its blade if ti were a lesser mechine i would say it could be the baerings but i see how hitachi makes tools so i would say its the blade got over heated at one time now when it gets hot it looses its integreity buy good blades as a rule
Nov 30, 2010 | Hitachi C10FL 10" Stationary Table Saw...
I have a Dewalt scroll saw and all of a sudden the cuts are irragular. it is fatter at the bottom then it is on the top, which makes for a bad fit. I have tired changing blades, made no difference. ...
Check the bearings in the lower part of the blade drive assembly (take the blade out to check) which may be allowing the mechanism to wobble. Also, check the mounting bolts holding the mechanism to the table. Hope this helps!
Nov 24, 2010 | Garden
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
How do you align the motor on an older (JET) JWTS-10 Table Saw. The manual does not go into it and I have looked inside the saw and can't find any way to align. The rear edge of the blade is out of...
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
May 11, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
The blade vibrates up or down after I set the height.
does this saw need an insert for the blade hole diameter or is the blade center hole too large for the spindle, that and make sure the flanges are on correctly and tightened.
Oct 31, 2009 | Jet JPS-10 ProShop Table Saw
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Delta 40-695 20" Variable-Speed Scroll Saw Logo
42 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
