Question about Caterpillar E70B Excavator
I have a Cat E70B (non blade model) All hydraulics work OK at low revs however, at full revs, power is lost in RH track, bucket crowd and auxillary function (bucket tilt) all else works fine?
2 Suggested Answers
  • 60 Answers
SOURCE: Cat D6R GJB00384 Hyd over heating from tank to pump tube. All functions work fine
you might want to contact a cat repair shop and explane your problem and most likely they will help out.
Posted on Aug 30, 2012
Takeuchi mini digger tracking problem
Pressure valve? does it only do it to only one side? Left or right. The reason you move both tracks with the bucket running is because you relieve pressure. One side is free wheeling, As they call it. I work on cars, But also have done to many hydraulic components. You have a pressure control valve that is bad.
Jul 10, 2016 | Mini Cars & Trucks
There is a pump in front on motor and i believe there's a pump in the rear end or transmission?
Paul
you have this in cars and trucks catagory and I have no idea of what car would have a hydraulic pump at front and rear
So I suggest that you ask the question again and next time include all the details like make, model , size, application , year as you want an answer with out the details
Jan 06, 2016 | Cars & Trucks
Hydraulics just stopped all of a sudden with bucket up. it will not move at all. what is the trouble shooting steps to follow
OK AL:
SAFETY FIRST!!!!!!!!!!!!!!!
The bucket up is DANGEROUS!
Get some blocking under it before you do anything.
If it were me, I'd find a way (Winch, Crane, Other machine, ???)
to safely support the bucket, then find a way to bleed the lift cylinders to allow the bucket to be lowered to the ground.
Then and ONLY then, I'd be looking at the hydraulics functions to determine if it was a valving or pump problem.
Jul 27, 2015 | Cars & Trucks
My fan runs but the compressor does not start on my whirlpool model ad25bsro so no water is collected.
1st ck that the bucket full light is not on , reguardless if bucket is m/t and in place , if light is on then the float sensor inside bucket container needs looked at , if no light is seen then it's common on new units to run the circulation fan all the time , and cycle the compressor on the humidistat's setting , reverify what the settings are for your room , std setting is 70%rH for a home , also a seperate meter to indicate %rh might help to determine if your unit is working properly (there not expensive) it migtht be that your room is dry enough and unit is not calling for water removal
Jul 01, 2014 | Whirlpool AD25BSR Dehumidifier
Do I have to split the track to install new bottom rollers on my E70B?
If you remove the plug for the grease cylinder on the idler arm and squeeze out the grease manually by pushing the pulley wheel in, you can relates enough tension on the track to sag it down and maybe remove rollers. Or you can remove the track this way with a little manual labor without splitting it.
May 30, 2014 | Caterpillar E70B Excavator
I have hydraulic oil in my radiator, e70b
I am not familiar with that particular machine, but I believe it would more likely be diesel or motor oil, unless of course there is a water exchange hydraulic cooler. If there is, check that for a leak to the coolant. If not, I would check compression on each cylinder, and/or look for signs of a blown head gasket. Other possibilities are probably more serious than even that. I hope this is helpful.
Mar 25, 2014 | Caterpillar E70B Excavator
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
Cat e70b wont start
Check the glo- plugs are working and check that the batteries are spinning the motor fast enough. Diesel engines need quick revs to heat the combustion air hot enough to ignite the diesel spray. If the engine is old you may need to have the injectors done as they have to atomise the fuel and not spray it in
Aug 11, 2012 | Caterpillar E70B Excavator
Caterpillar E70B Excavator Logo
117 people viewed this question
Top Caterpillar Garden Experts
J.D. Browning
J.D. Browning
downhille
Bill Boyd
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
