Sanyo Aircon set at 16 degrees and at high power is not producing cold air but only air at room temperature and the green operation light is blinking.
    Genius:
  • 1,669 Answers
Sounds like the compressor is no longer working or the refrigerant is in need of recharging.
Posted on Jan 10, 2013
2 Suggested Answers
darjr
  • 378 Answers
SOURCE: Aircon problem
check the filters maybe its full of dirt.
Posted on Jun 07, 2009
Output temperature
Air conditioners will cool 16-20 degrees. So if the house is 80 degrees, 63 degrees is a good output. If the house is 72, the air will be colder. The higher the humidity, the lower the temperature drop will be because the A/C has 2 jobs, to cool and de-humidify. So if the house is humid, the drop will be lower.
Jun 04, 2015 | Heating & Cooling
Cannot set correct temperature with remote
the 16 on remote is the set temperature not the room temperature.
Jan 25, 2014 | Heating & Cooling
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
My AlP-12000 EH Portable Air Conditioner blows hot air
dear sir
please test your aircon with digital temperature meter i mean take first room temperature data then check your aicon flow air temperature it should be lower than to 20-22 degree Celsius if it,s not low like this
then it can be low freon problem in your aircon system.
thank you
hope answer the question
Sep 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
I could not make my aircon work. When i turned it on using the remote control, the operation and timer light will blink together. The fan would not spin. No matter how many times i've turned it off and on,...
The problem is on electronic control units in the indoor air conditioner, there are two temperature sensors, sensor pipe evaporator and room temperature sensor. one or both of these sensors is defective, so that electronic controller error and showed signs of a green and yellow light flashes. You must replace both sensors with a new and appropriate size (specification).
Aug 25, 2010 | Samsung Heating & Cooling
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
Air is not cold
there could be a number of reasons. 1 would be thre is no more freon on your AC unit. the other is that the capacitor for the compressor is already busted. Have this fixed by your local aircon specialist.
May 24, 2010 | Sanyo 18KS52 Air Conditioner
Not sure how this thing works
Is the air coming out of it cold? It will take a while to cool the whole room down. If it isn't cold then maybe it is short of gas (caused by a gas leak) This may be the reason it was a factory second!! :-S Also, setting it for 16 degrees as opposed to 23 degrees won't make it work any harder. That will be why it runs forever. Air con's usually can't get a room down to 16 degrees!
Jan 16, 2010 | Heating & Cooling
Aircon problem
Jun 06, 2009 | Sanyo Split System Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
