Question about Ovens
Britannia range cooker dual fuel, main fan oven switches on, seems to run up to about 150 then turns everything off and the clock then starts to flash, have read the link on the thermostat failing safe, the fanseems to be fine?? had a look in the wiring diagram and there appears to be a "safety thermostat" as well, any one with any help at all would be great, parts are quite expensive and dont want to waste money. many thanks Brian
  • 1314 Answers
SOURCE: Oven Overheating with Fault Code F1 displayed after reaching temperature.
it varies first thing to do is check the connections if there is a plastic ribbion on yours can clean it with a pencial eraser unplug the wires and plug them back up a couple of times in case there is some restiance there now by sensor i assume you are talking the oven probe some where on your range you will find a techsheet that will tell you how to ohm the probe and they dont always
show the right code that should help let me know what you find ill be here
Posted on Jan 24, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
  • 39 Answers
SOURCE: electrolux icon dual-fuel range installation problems
its a bad EOC .Electronic Oven Control....You need to replace the board
Posted on May 22, 2009
SOURCE: Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Posted on Dec 30, 2009
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Dec 30, 2009 | Ovens
Oven not working, but clock is
there may be a damaged copper link at the box where the power supply goes into the back. it may have also come loose in the connector box.
Mar 11, 2009 | Ovens
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
