Question about GE ZSC2001FSS Advantium Electric Single Oven
Microwave Oven Fan and turntable stay on continuously
Fan and turntable run continuosly and wont turn off. I changed the main board because I thought for sure it was a bad relay (RY17) that controls both the fan and turntable motor. But changing the board did not fix the problem. Now I am stumped, any help would be greatly appreciated.
  • Nick Gravina Jan 07, 2013
    Also, wanted to add. The fan heats fine, just doesn't turn off.
SOURCE: No heat or rotate
Hi, I have the same problem, no heat and no rotate.
How can I check the door switches, how can I determine it is good or bad.
Do I need to open that front panel on the right hand side to check the in side.
Thanks a lot.
Wendy
Posted on Mar 28, 2008
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
SOURCE: JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Posted on Mar 04, 2009
localwonder
  • 6784 Answers
SOURCE: Flashing locking door light
This is a failed logic chip on the control board. replacing the control board will fix this issue.
Posted on May 27, 2009
  • 8 Answers
SOURCE: Turntable not turning
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Posted on Aug 21, 2009
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
Oven blown up??? Is it a simple fuse or is it a big job???
sound like fuction switch has blown apart quite common and the noise is prob coming from cooling fan and not the main one inside.
Sep 14, 2009 | DeLonghi Ovens
Won't turn off
Sounds like maybe a wire burned off of an element terminal and shorted to ground. This would bypass the thermostat, so to speak, and continue to heat at 1/4 wattage. The only way to control this failure would be to turn off the power to the oven, but it won't reset until the burned wire is repaired.
May 27, 2008 | Maytag CWE4800A Electric Single Oven
GE ZSC2001FSS Advantium Electric Single Oven Logo
27 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
