Question about Canon imageCLASS D320 Digital Copier
Canon ImageClass D320 makes grinding noise at paper tray
Loud grinding noise (like plastic gears slipping /stripping teeth) seems to be coming from paper tray area. Starts when machine powered on, lasts for about 8 seconds. Then machine shuts down with error light.
  • srsbmk Jan 07, 2013
    It also appears that the "paper elevator" is stuck in the down position on the left side. The right side still moves up and down.
  • srsbmk Jan 11, 2013
    Can't see any broken or stripped gears. Any suggestions?
4 Suggested Answers
  • 15 Answers
SOURCE: Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Posted on Jan 12, 2009
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Posted on May 06, 2009
  • 1126 Answers
SOURCE: How to use Canon Imageclass D320 from Macbook pro?
According to this Canon site, there are no Mac OS drivers available for the ImageClass D320.....only Windows Platform.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=9036
Posted on Sep 29, 2009
The red alarm light keeps blinking and as we open and close the right it make continuous noise at the bottom of the paper tray for 30 seconds and it don't catch the paper
the better call the technician.
because I think there is some gear has broken/loosen.
but first you can check it. perhaps that is just a rubber(pick up roll) was slick.
so can not catch the paper.
May 27, 2011 | Canon imageCLASS D320 Digital Copier
I am working with a canon imageclass d320. I believe there is a problem with the fuser and am wondering how i can gain access to the fuser? There is nothing in the manual about the fuser either.
from the left side of machine there are door, when You open them you will have access to fusing unit, but only to the paper exit section.
To dismantle the machine you need to strip all the plastics and much more...
Apr 11, 2011 | Canon imageCLASS D320 Digital Copier
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon imageCLASS D320 Digital Copier Logo
187 people viewed this question
old marine
old marine
